Oh yeah.
I'm loving a lighter e-bike. The suck that I didn't enjoy with my heavy full power is all but gone. Those sucks were, terrible to pedal without motor assist, Terrible to manual, sucky pop, worse on steeps and super tight tech.
My old bike was 25.5kg, new bike weighs in a 21.8kg all in and what a difference in ride. Ok the actual bike has a lot to do with it too. Bike type aside, its immediately easier to maneuver, pedal, pop and manual. Its a lot closer to an mtb experience than the heavy bike.
Now I did think long and hard about a mid-power bike. But after riding the light weight full power i'm convinced it was 100% the correct decision to stay full power. I have the motor detuned to 60nm in eco, 70nm in tour, emtb is stock and turbo is wanged up to full assist.
I'm running 400wh and 600wh batteries. This far 400wh is my go too battery size. (thats the 21.8kg weight). I hoon around mostly in 70nm tour mode and can get 2 hours and 1000mtr vert out of the battery. But when climbing steep tech there are times when 70nm tour mode doesn't cut it and need to switch up to emtb or turbo mode. A quick squirt in boost up an over a tech sections does sweet fa to the battery life if you switch back down to tour mode after the squirt.
Effectively i'm getting the best of both worlds, a lighter weight more playful bike with the ability to smash full power tomfoolery literally at the flick of a switch.
Also having removable batteries with different capacity's also ramp up my options. Unlike most mid powers (which typically dont have removable batteries) I can swap out a battery and keep riding, or put a bigger battery if an epic wilderness ride is called for. So I dont have the range anxiety of the mid power user who has to stop riding his bike when the non-removable battery goes flat.
Also my combined wh of both batteries is 1000wh and that exceeds all full power options without range extender batteries installed.
Booya.
Booya.
