1 - 4 of 4 Posts
andrewface
· Registered
Discussion starter · #1 ·
Can someone help me out with this? What length of mounting bolts do I need to directly post mount (180mm rotor) a shimano brake caliper to a rockshox pike? Can't figure this out with a google search and it's driving me crazy! thanks in advance.
A general rule for threaded fasteners to be safe (steel bolt into aluminum thread) is 2x the nominal diameter of the fastener. i.e. if you have a M3 bolt then you want at least 7.5 mm of thread engagement length. This 2x ratio should give a factor of safety.
The design principle is that the bolt should fail before the female thread shears. Since you likely have a steel bolt going into a softer and lower strength hole you should add a bit of engagement if possible.
Your fork lower is likely magnesium so I would run a minimum of 2.5x engagement unless the spec indicates otherwise. Ideally you should check with the fork manufacturer for specification.
1 - 4 of 4 Posts
