A gripe has led me to make this post. Rather than just talking about my gripe, I’m hoping we can use this forum to make observations, good and bad.
The good:
• Reduced hand fatigue on long descents
• Handles those tough “Uh-Oh!” moments quite well
• Inverted design keeps those seals cleaner, longer
The bad:
• Inverted design has led to rock chipping my Kashima coat, at least on my brake side
• Torsional stiffness (or lack thereof) is noticeable in low speed technical sections
• Tapered steer tube makes for a tight SWAT kit fit
Now quite obviously, what I’d like to talk about here is the rock chipping on my lowers, which in this case, are the delicate Kashima coated sliders. Right now I have three small chips in there, all in about the same spot, from at least two separate incidents. At first I thought coincidence, but a subsequent ride I heard a sound distinctly like a rock hitting my rotor and then something else. It occurred to me that what was happening here is that small rocks are being basically fed into my slider tubes. Not good!
Now I have discussed this with Fox, who says I should replace my slider tube, not under warranty. Sure, I get it. But what I really want to know is: are they gonna address this problem? Conventional non-inverted forks have a lot of hardware in the way blocking this type of rock behavior, namely the caliper mounts. On this fork there’s just nothing in the way. The guards don’t really wrap around the back side. They could, but they don’t.
I have half a mind to build an aluminum bridge from my caliper to the guards, or something. 🧐
