Seen on multiple bike at Sea Otter the Fox RAD prototype USD fork:
This is idiotic, sorry. Fox totally screwed the vvc damping a few gens ago for no good reason, with literally no compression damping. There are many examples of this where they totally screwed the pooch on products. Blind devotion is dumb.people use way too much hyperbole on forums. “Brand X feels way better than brand Y”, or “brand X sucks and their damper is ****”.
Reality is
1) most people don’t have their suspension setup well
2) as long as you’re in a normal weight range; a Fox 38/36 or Zeb/Lyrik is not holding you back from anything
3) people love to hate on the big brands
I don't actually many pro's actually get that much say over what they get to run. A few, absolutely, but the bulk I'd say not a chance.Like I said, "I’m sure a lot of them custom tune. Doesn’t mean Rockshox or Fox make a bad product."
And the fact that a pro chooses to race the stock lyrik damper (when he could run anything), and is winning on it.... beating every other pro whose on the same level of training...should count for something.
LolI don’t think you understand. Generally pros have suspension camps before each season, and tuners provided by the suspension company will custom tune the damper if needed (usually using data acquisition). I know Richie uses custom tunes. But Charlie was winning on the stock tune. Point is the current gen stock Lyrik is badass.
Over five years ago on the old Lyrik (before the Zeb was out) people didn’t like the stock airspring. It was commonly known their factory riders ran luftkappes because they knew it was better. Don’t know of modern examples of this with a fork, but goes to show that if there’s something aftermarket that is better, pros will use it, as long as nobody can see it.
Someone will probably accuse me of being a Rockshox rep now for saying the current Lyrik is good.
That’s the thing, most pros are riding the same stock stuff you are with the exception of the very top riders. Your average national level pro or privateer World Cup rider are not getting custom anything and they can make it work.This might be the most idiotic take I've heard in a long time... So because I'm not an EWS/DH athlete I shouldn't expect my suspension to work correctly?
Weight weenieism aside, weight is still important. We have to pedal these things uphill, lift the front wheel over things etc. That's where USD is always going to struggle. Don't get me wrong, I love the concept, had three Shiver SCs which to be fair weren't a great fork. But if the weight creeps up then dual crown forks start to come into the picture and something that probably should have been considered a few mm ago in terms of travel.I think the weight of the new USD Fox fork is what a lot of people are going to be looking at, at least it will be for me.
Unless you weigh 140lbs soaking wet, leave the HSC open on a Fox fork and you'd be fine. If you're still having issues, it's not the fork.
Perhaps you meant 240lbs. Running HSC wide open surely means you need the compression reduced.Im saying at your weight you don’t need a retune on a modern fox fork. Stop twisting words.
