Fox 32 seal replacement (07-09)
1.1K views 2 replies 2 participants last post by  jbsmith
#1 · (Edited)
The fork is between an 07-09. It's a Float 130mm RL.
I can rebuild these forks, but I'll be damned if I can remember which one is which when it comes to where the oil goes! So... I'm just replacing the seals and foam rings.On fox's service page (#27), it calls for 10wt. in the "Damper-side oil bath" 160ml and "Spring-side oil bath" 30ml. I'm pouring 160ml in the top of the fork, right? Otherwise it has 5ml of float fluid in the air chamber. I wish they'd change it to top, bottom, left and right... Thanks for your help, Fahn
