OK so I'm a fat dude at 300lbs with my riding gear. Also my comments are just opinions and not bashing Stans in anyway. 4 rides on some newly built hadley/flow/rampage wheels. At the time I was running close to 36psi in the tires with a single wrap of yellow tape. Rampages went on a little easy but did seem to seat with air compressor being uses a my air source. First real solid impact and I believe I burped the tire. Angle of attack was a little off center as I was turning to a small degree. Last recored GPS says I was moving around 13.1mph. After rolling around on the ground for 30 seconds catching my breath I noticed the semi flat front tire when picking up my bike.
So on with asking the questions with the people at Stans. They suggested big riders or riders pounding the ground should use the Flow rim strip with the Flow rim. Ordered them up with a new set of Rampages, which according to Stans was an OK tire to use with their rims tubeless. Added the strip and still feel the Rampage mounts to easy. So at this point I'm back to running tubes with the Rampages. Chad at Red Barn is sending me a Racing Ralph and Mountain King to see how these tires will mount. I absolutely love the tubeless feel. But I have my concerns this tubeless ready is not really as confidence inspiring as a true UST setup.
So what do you all suggest. Try another wrap of yellow tape with the flow strip? Look at other tire options? If so which tire would be suggested? Run tubes until we have a UST tire and rim combo.
