e*thirteen Quick Fill Plasma Valve
6.6K views 39 replies 19 participants last post by  JustRon
#1 ·
I run cushcore both front and back on my bikes and use their valves with no issues. However, the Quick Fill Plasma Valves from e*thirteen look appealing with the following features:
  • The Quick Fill Plasma Valve is cleaner, easier to use and more reliable
  • Oversized valve stem allows for sealant injection direct from the bottle, mess-free
  • Tool free removal of the valve body and core allows sealant installation without gumming up the valve - This feature allows for easy cleaning without taking the tire off
  • Sealant can be added without breaking the tire bead and without any tools
  • Available in two lengths to accommodate most rim profiles.
  • CNC machined. Aluminum alloy construction.
  • Available in five anodized colors.
  • Spice it up! Coordinate with other component colors and leave the mess behind.
Who has tried these valves? Please share your thoughts and experience with us.
#4 ·
Not exciting as either of those...
#5 ·
These are cool although I've never had trouble injecting sealant into a tire through a presta valve stem after I remove the valve core. It's easy and not something you really have to do that often. Still I like blingy things like that so I'm in. It's like the Wolf Tooth pack pliers. Pretty cool but I have several pairs of "sawed off" chain link pliers that I go on Amazon for five bucks each that are lighter and do the job.
#7 ·
Valve wars. Good. Tiny presta is ill-suited to the realties of tubeless, namely setting beads...but also gunking up.
#14 ·
The Reserve Fillmore valves are expensive, but amazing. For me, they are the gold standard for valve stems.
It's amazing how something so silly, like valves, can make such an in-use, real world difference.
Seating tires with a crappy floor pump, no problem. Clogged or restricted valves, not anymore!
#15 ·
Can seat my tires with Stans valves and a standard floor pump for half the price. And I don't have to feel bad about giving Reserve Wheels more money than they deserve. 😎
#17 ·
I have the previous version of e.13's valves and have been using them for years. I've been pretty pleased with them, though the 2 piece design they use (I assume these use a similar design) requires some attention to get them installed correctly withough leaks.
I'll pay $25 for valves. Won't pay $50 for the Reserve valves no matter how good they are. They're not twice as good as these, or 3x as good as the cheaper Stan's valves.
#29 ·
The supplied presta valve with removable core that came with my XT front wheel works just fine. Same with the Sunringle rear wheel. Remove core, insert pointy nozzle of squeeze bottle, done. If it ain't broke, why fix it? Fools and their money are easily parted 🤣🤣
#34 ·
I've spent a lot more than 30 minutes messing with funky valves, which is more time than it take me to make Filmore money.
On the other hand I've only been on the bike 2-3x in the last 8 weeks due to a crushing work load, personal & professional. Time is of the essence at this point in my life.
It's all relevant.
#35 ·
A lot also depends on what sealant people are using. Stans Race just doesn't play nice with and valves with cores. I mean it's so good you can't inject it with any valve, it even seals up the injector.
The Fillmore valves at least don't become clogged though, and when popping tyres on at first, they just allow so much more air through.
#38 ·
I'm confused. In the video on e13's page, Aaron Gwin says it's easier than breaking the bead to add sealant. Why would you need to do that? I just remove the valve core (the same procedure as for the e13 valves) and add sealant. It would never even have occurred to me to break a bead to add sealant. What am I missing?
#39 ·
Some valves, like my Milkit, have another valve that supposedly prevents passing of sealant into the valve stem, except, that same valve makes it impossible to squeeze stan's bottles into the stem, you need a high-pressure syringe, which is just dumb IME to add sealant, so with these valves, it's easier just to break the bead, then run around and get a syringe and have to deal with that added BS.
  • Like
Reactions: JustRon
