Any opinions on these hubs ? They are on a wheelset I am thinking about purchasing ? Read they only have 18 points of engagment but use a star wheel ? Is this ok ? Thanx
The 340 is a less expensive, heavier version of the 240s (mainly because of using steel in place of aluminum in places). Good hubs. I would have no reservations in using them.keen said:Any opinions on these hubs ? They are on a wheelset I am thinking about purchasing ? Read they only have 18 points of engagment but use a star wheel ? Is this ok ? Thanx
Sorry it is not completely clear to me what you are saying here.Jerk_Chicken said:I have both and they look the same internally, just hubshell differences and not for a pricepoint, but for the purpose of greater durability due to the thicker flanges.
DT Swiss said that the 340 hubs have larger bearings. So you can't convert. For that reason, I would get the 240s or the 440. I have 340 on one set of the wheels, and I am stuck with 5mm.Jerk_Chicken said:Do you know what is the reason? I could swear the same parts apply to the 240s and the 340.
You can't go wrong with these. Get them.keen said:Any opinions on these hubs ? They are on a wheelset I am thinking about purchasing ? Read they only have 18 points of engagment but use a star wheel ? Is this ok ? Thanx
Well I purchased the wheelset only to find out the next day I couldn't do any rear thru axle conversions :madman: May have to put them on the auction block .Cable0guy said:DT Swiss said that the 340 hubs have larger bearings. So you can't convert. For that reason, I would get the 240s or the 440. I have 340 on one set of the wheels, and I am stuck with 5mm.
You may be able to convert the rear from 5mm to 10mm. I think this may be possible, but not the front. The only problem is that this only marginally improves the rigidity (unlike the front), and would cost something like $50 for the thru-bolt and $50 for the new end caps. Check with DT Swiss and let us know.keen said:Well I purchased the wheelset only to find out the next day I couldn't do any rear thru axle conversions :madman: May have to put them on the auction block .
In the U.S. the 340 costs ~25% less than the 240s, more than a small amount less in my book.Jerk_Chicken said:That's exactly what I mean, yes. THe 340 was not made to satisfy a price range. In fact, the only reason it's a small amount less is because of less machinework. It was designed for heavier duty than the 240s. Internals are the same.
But still less expensive than the 240s. I never said they were cheap or a bargain.Jerk_Chicken said:And they are still expensive, relatively speaking, even with 25% off because the 240s is an expensive hub.
Ya I contacted DT Swiss directly on Fri. Said the 340 rear was available in QR or 10mm but neither is convertible.Cable0guy said:You may be able to convert the rear from 5mm to 10mm. I think this may be possible, but not the front. The only problem is that this only marginally improves the rigidity (unlike the front), and would cost something like $50 for the thru-bolt and $50 for the new end caps. Check with DT Swiss and let us know.
