1 - 20 of 25 Posts
phoeneous
· :\ ping of death
Discussion starter · #1 ·
Right now I have a 34t single ring setup but I need to get a chain guide. Its a toss up between the e13 SRS or the BlackSpire DS1. The only reason why I would go with the DS1 is because it comes with a 38t ring. Otherwise, Im getting the SRS.
So, does a 38t ring have benefits over a 34t ring?
What's your gearnig in the back and where do you ride? Answering those 2 questions might help you decide what is best up front. I run a 38 in the front with standard MTB 9 speeds (11-34) in the back and it seems to work out OK here in the northeast. Other friends ride a 32 in the front with a tighter road block in the back, almost equaling my gear ratio. It seems that a lof of people who ride the tight northeast dh terrain use an easier ratio.
do you ever RIDE that bike you're going to "upgrade"?
of course 4 more teeth on the front chainring matters. if you don't know that fact, and why exactly the 4 tooth difference DOES matter, you probably do NOT ride your bike and spend more time posing around the neighborhood and posting stoopid Qs on the internet.
look at it this way, Junior: when you run a front derailleur, you use TWO DIFFERENT sized chainrings, and the bike's pedaling changes with the choice of front chainring. your gear ratio changes, your ability to pedal the bike changes, the distance the bike travels for each full crank revolution changes.
jeezus, learn about your bike already. :rolleyes:
A couple of things must be sorted before this question can be answered... On your local trails, do you find yourself spinning out on the descents (wishing you had a higher gear to apply more power and speed), or are you suffering most on the climbs. The 38T will gear your bike higher, but you may find yourself pushing it more often until you get your strength up.
Discussion starter · #8 ·
Thanks for nothing cake boy. Ever heard of converting to single ring or are you a dumbass as much as you are a prick?
Perhaps pictures will help your feable brain process the information.
Now go play with timmy and his dolls mmkay?
phoeneous said:
How could it apply if I dont even have a front derailer? Or is that too difficult for you to comprehend from the pictures?
derailleur or no derailleur, there is still a difference between a 34 and a 38, as described in gonzo's post. go re-read it cake boy....
start with this ..."the bike's pedaling changes with the choice of front chainring. your gear ratio changes, your ability to pedal the bike changes, the distance the bike travels for each full crank revolution changes."
That is a big jump in tooth count. Looks like you just got your bike... you better ride that ring around a bit before you buy that 38. If you find you need to be in hardest gear in the back, then you should get the 38. If you find that your in the easiest gears, then I wouldn't change the gearing.
Just so you know... this should have been in the drivetrain forum, they are nicer there as well.
Discussion starter · #14 ·
How would I know what a 38t ring is like if Ive never had one? Figure that one out genius. What part of 34t o you not understand. Here, lets try simple arithmetic: 38 - 34 = 4. Now, go read the title of this thread give me a worthy reply to read...cake boy.
You shouldn't try to annoy the guys on this forum. They will nag you forever. Look at what BJ- goes through. They will never forget if your a dumbarse.
listen up! all retards please pay attention...
1 - 20 of 25 Posts
