Most headsets are installed by pressing some sort of cup into the frame. These designs use friction to stay in place so ideally you want to have a specific amount of friction. I either install with the cups and headtube clean (acetone or similar) and dry or with Loctite 242, to seal the interface if corrosion is a worry. Though some installs will require a retaining compound, depending on the tolerance (which should be checked first).
