help! bikes almost done as you can see in the pic. i have a truvative giga pipe bb 73x118 and this is the crank set i am using Truvativ Hussefelt 2.2 RG Crankset 2010 at Price Point
this is on a 2009 kona five-o frame. when the crank is on, it hits directly in line with the chainstay. its bad. not rubbing but straight up flush with it. seems like the bb needs to be wider or something, or the cranks need a huge flare to miss the chainstays.
what could be going wrong?!?!?!?! anyone run into this problem before?
