1 - 2 of 41 Posts
If that is the case I would just pick up a set of stans valves and their injector makes like easier even easier if you buy their core remover it works on both shrader and presta. who caboodle should set you back around $30 really makes set up and maintenance easy. Plus with the injector you can add sealant to shrader and with a little work presta tubes.
1 - 2 of 41 Posts
