Convert to coil shock on Kona Process 153
6.8K views 4 replies 3 participants last post by  atkinsal
#1 ·
Hi all
Wonder if anyone can help. I'm looking to swap out my rock shox super deluxe air shock for a coil.
This is partly because I managed to bugger it in a crash last year (scratched the damper body and broke the seal). I had it repaired and it holds air ok but I like the idea of not having to worry about it failing again, particularly mid-way through an Alps trip which is what happened last time.
I also think my riding style would be better suited to a coil.
I'm riding an XL 2019 Kona process 29er, CR, DL.
The air shock is a rock shox super deluxe 205/60mm trunnion.
I was thinking for going for an equivalent size rock shox super deluxe coil shock.
Here in the UK there are currently decently priced shocks online with the following description:
'RockShox Super Deluxe Ultimate Coil RCT 205x60mm Trunnion Rear Shock for Norco Range 2017+ - black'
They reference the 'Norco Range' but the stats / dimensions etc seem the same. I can't see why it wouldn't fit. As my air shock was trunnion fitting I'm assuming the fittings would be the standard width / bolt pattern?
Grateful for any thoughts.
Alex
