I've never had an issue getting pressure where I want it on air shocks, but I'm having a hard time finding the right setup for my first coil shock. I just got a SC V10 with a Fox DHX2 coil shock. The shock came with a 500 lb/in spring, and I am around 190lb on the trail. So I think it's the right spring for me. But, I'm getting confused on the preload instructions, which say that you should turn the preload collar a max of two full rotations past the point where it stops being loose. For one thing, my preload collar is never loose; it's fused to the spring. But there is another C-shaped washer below the spring which is loose up until a certain point (although that point is kind of nebulous, since I can get the spring compressing a bit and still rotate that C-washer if I try hard enough).
I have added as much preload as is supposedly safe (the 2 full turns past the point where I can't rotate the C-washer anymore), and looking at sag it seems to be in the right ballpark, but the thing that throws me for a loop is the shock seems to be bottoming out extremely easy, like after a short moderate trail run. With my air shocks I've always had them set up to only bottom out a couple times per day after really big hits, but it seems like if I wanted to do that with this shock I'd either need to turn the preload past the "safe" point, or put a much stiffer spring in there (which shouldn't be required at my weight, I don't think). Are spring shocks just expected to bottom out more often?
