I’ve always used Speedplay Frogs and with Wahoo no longer supporting the cleats I need to find a new pedal. What do you think about clipless pedals with a platform? It seems like the platform would make the pedal fiddly getting into.
I always feel the support from the platform (Funn Ripper) and don’t have problem with the float or releasing my foot when needed, but it depends on how high are your pins.The platform is useful for when you're not clipped in. Like, getting back on the bike on a steep incline, and needing a few pedals before getting the other side clipped in. Or, if you need to dab in a technical section, being able to pedal through the rest before getting stable enough to clip in. Otherwise, the float that's built in to any clipless pedal literally wouldn't work.
haha I hear that... I tried to explain the difference between "wanting" a bathroom remodel and "needing" new bike parts to my wife, but she doesn't seem to get it.I’ve also had great luck with their flats. I’ll for sure be getting a set of their clips.
It’s going to have to wait till I’m closer to riding season. At the rate $$$ is flying out the window with our kitchen remodel, if I buy anything unnecessary right now, I’m getting a serious punch right in the dick from my wife…
I've experienced the "common" seal popping out on one set, which I rebuilt not long ago. I added a bunch of o-rings on the spindle, which help keep the seal in place. My other set has been going for nearly a season and no seal popping. So far, no complaints.I have been running the same XTR pedals but they bearings wear really fast. I take them apart each winter, clean and grease them. but if I get two seasons out of them, I am lucky.
Because I have the mental capacity of a 13 year old, I was expecting a “yo mama” joke…You know what’s NOT fiddly to get into?
Flat pedals.😉
Yo mama so flat...errr...nm. 😂Because I have the mental capacity of a 13 year old, I was expecting a “yo mama” joke…
Personally, I've never found any clip pedals "fiddly" to get into. I've used just about every type. From the flat pedal looking DH ones to the minimal Eggbeaters. The way you have your cleats adjusted can have a lot to do with how the shoe interfaces with the pedal. Some shoes have some really deep lugs and the cleat can be buried deep in the sole. That can usually be remedied with some cleat spacers. As the sole wears, you can remove the shims.I’ve always used Speedplay Frogs and with Wahoo no longer supporting the cleats I need to find a new pedal. What do you think about clipless pedals with a platform? It seems like the platform would make the pedal fiddly getting into.
I did the same with the 0-rings based on an older post, maybe from you. It helps but the seal still does not stay all of the way in on the older design. I did purchase a new set of XTRs last year but did not ride much. Hopefully, Shimano's newer design address this issue.I've experienced the "common" seal popping out on one set, which I rebuilt not long ago. I added a bunch of o-rings on the spindle, which help keep the seal in place. My other set has been going for nearly a season and no seal popping. So far, no complaints.
I have a set of Mallet E's as well. They work great with my old-skool Bontrager RL mountain shoes, nylon sole and all.Crankbrothers Mallet E. I was a flat pedal rider and wanted the same feel. Tired many different pedals and the Mallet-Es were exactly what I was after. Easy in/out but with a good platform you can actually feel. I do run them with Crankbrothers shoes also however.
