I moved this post over from the Cheap Chinese lamp thread so the discussion would not pull the other thread off topic.
For the heck of it I looked up the info on the so called "fake Cree" LED's made by Latticebright ( Chinese company ). The data available on their XM-L2 clone ( known as the XM ) is limited. There is no dedicated data sheet like Cree but there is some information. Anyway I compared what info there is to the Cree XM-L2 data sheets and here's what I came up with...
Comparing at 700ma, 85°C...Minimum expectations ( cool white? ) U2;
Cree XM-L2 U2....300 lumen
Chinese Latticebright XM ( bin unknown )....240 lumen ( typical is listed as 300 lumen )
Cree did not list a typical output at this level although likely it is somewhere around 350-360 lumen.
I'm not saying I would want a lamp made with the Chinese LED's but the tech behind the Chinese LED's is not too far behind the Cree LED's. Actually it wouldn't surprise me if Cree tried to buy the Chinese company just so there is no confusion in the market place between the two. Heck, they now have Chinese Kentucky Fried Chicken, why not a Chinese Cree.
Yes I agree 100%.Without additional data, it is tough to decide just how far behind they are from Cree or other "high end" LEDs.
I'd really like to see what their output curve at high current is. IIRC XML is ~230% at 3A over the 700mA output.
They just happened to pick almost identical model/product names? Just different enough not to be noticed by most.The company that makes them does not intend to sell them as Cree
Already happening as documented at BLF and some members here. They are Chinese manufacturers, they'll say and advertise whatever they think will sell more product...... Now if a manufacturer or seller tries to market these as "Cree" then the people doing that are making false claims. The Latticebright emitter boards themselves ( according to the photos I've seen ) seem to be well labeled. Of course this doesn't mean that someone who is selling the end product won't try to remove the labels and then claim they are Cree. Trying to ID the emitter by sight is not always going to be easy, even if you know what to look for.
^^..Yes, we've seen this before so I know it can happen. It doesn't mean that all the Chinese lamps will be using Latticebright emitters with fake Cree labeling.Already happening as documented at BLF and some members here. They are Chinese manufacturers, they'll say and advertise whatever they think will sell more product.
Same with bins. They advertise U2 or whatever premium bin is hot, but IMO they are never putting premium bins in the lights. They can save some money by buying a couple grades lower on bins and the user has absolutely no way to tell the difference.
^^..Well if Latticebright had named their company "Crei" I might be more inclined to agree with you.They just happened to pick almost identical model/product names? Just different enough not to be noticed by most.
Nope, Lattice Bright and the companies using them are trying to confuse the uneducated that they are using Genuine Crees.
jjziets, Thanks very much for your post. Just looking at the photos you provided shows how very hard it is to identify the clone emitter.....It was no surprise that the Lattice Bright XML2 T6 did not compare well against the Original Cree XM-L2 T6. The advantage at 35deg is not that big but as the temperature increases the Cree increases its lead. Sadly the difference is not really that big even at 100deg with only a 13.8% lag in Luminous efficacy of LB. If the quality (Colour) of the light was no concern one could be excused to think the lower price point and the marginal loss in light can be accepted. But that would be ignoring the fact that Cree XM-L2 comes out in much higher bins. The U3 bin would have a Luminous efficacy of 112 lumen/watt at 100deg compared to the 82.3 Lumen/watt of the LB LED at 100deg. What this test does not address is reliability but if build quality is anything to go by then the Lattice Bright LED's should be avoided.
Cheap lights are often plagued with bad thermal design and the use of low quality thermal past if any results in the LEDs running very hot. The effect is that this clones will find themself in host that would put them at a very big disadvantage to the higher quality and better performing Cree counterparts. This is just one more reason why brands add value to a product.
