Chain skips under torque, but shifts fine, thoughts?
29K views 19 replies 12 participants last post by  ribbs76
#1 ·
Seeking help.
I have an Ibis Hakka MX. 1x 11spd SRAM Rival derailleur, stock Praxis chainring, XT 11 spd cassette.
I just replaced a stretched SRAM 11spd chain with a Shimano 11spd chain.
The gears shift fine, no noise no issues. However under toque on the lowest gear (smallest cog) the chain will skip. I don’t mean it shifts cogs, as far as I can tell, but feels like it gives way and skips over the teeth on the derailleur jockey wheels….I think. It only happens under real torque when accelerating, smooth climbing seems to be fine. Hard to tell exactly when riding and can’t reproduce the torque in the stand.
I’m told brand for 11spd drivetrain doesn’t matter that much but I did go to a shimano chain to match the cassette.
I matched the old chain length with the new one. I’m wondering if maybe I’m a link too long.
Any thoughts?
#6 ·
Ime there's nearly a 100% chance that you need a new cassette, or at least replace the cogs that are skipping.
When replacing chains it's super common to get skipping under load . It happens because a stretched chain was run too long and deformed the cog(s) When a new ( shorter) chain is installed it doesn't mate up well.
#11 ·
I had skipping on my small cog caused by installing the master link incorrectly on a SRAM GX chain. Arrows on the link weren't pointing toward the direction of rotation. I don't know if this would apply to a Shimano chain but someone here should know.
There are arrows on shimano as well. I’m good there.
It’s starting to sound more like a new cassette maybe chainring while I’m at it. The old chain was fairly stretched!
#13 ·
I had a similar issue when I replaced the chain on my XT 12 speed drive train. Didn’t skip but makes a bit of a grinding sound when torquing hard in the three lowest gears.
The cassette was a year old with about 2500 miles on it. I assumed it was worn, but I also assumed (hoped) that as the chain got to know the cassette a little better it would quiet down some and run a little smoother under load. 4-5 months in and maybe it’s a bit quieter, but not so much.
#14 ·
Thanks. Yes agree, sometimes the new chain on old hardware can take a while to settled in and makes a lot of noise while doing so. I’m not sure this is my issue though. I’m leaning towards a new cassette, maybe chain ring. I’ll buy a couple
extra chains and replace them more often I think.
#15 ·
Mine was doing this recently and it was a bad link in the chain. It was actually damaged from an impact. Then I made the dumb mistake of installing the master link backwards, and reusing an old one. Stupid. Ended up breaking it again in a completely different spot (that was also impact damaged). Bit the bullet and bought a new chain. Runs much better now.
#18 ·
FWIW, I discovered last night as I was cleaning and lubing my new chain that my E13 helix cassette is basically shredded. Like 3 of the steel cogs are bent, the aluminum rings are fine which is wierd, Don't know what happened there, whether it was a hit or just the massive torque I generate :) but that is definitely contributing to my issue, so check your cassette too. Tooth wear looks good too. IDK what happened.
#19 ·
