I've had 2 flats on my DH bike this year. I've been lucky in that I wasn't that far from the bottom of the park, but if I'd been way up Garbanzo or something, it would have been a lot worse. So I'm trying to figure out how to carry the minimum to be able to repair a flat. First thing I have to do is get my bike converted to tubeless. In the minimal flat situation, pushing in a plug is a lot easier than getting at the tube to patch it.
Great. But my DH bike doesn't have any convenient mount points for a pump. So alternatives are: 1) strap or clamp a pump on somewhere, 2) carry a pump in a backpack, or 3) carry CO2 cartridges and applicator.
#1 on the surface seems like the easiest solution, but the question then becomes exactly where and how to clamp it on. You don't want it bouncing off, coming loose, getting in the way of the tires, or getting crushed when you case badly.
#2 requires you to always wear a backpack. I mean that's not terrible, but it seems a big ask to carry something you might never use.
#3 requires you to either strap the CO2 kit to the bike (see #1) or carry the kit in a hip pack (see #2) or get one of those OneUp kits, and I'm not sure if there's a place on a DH bike for one of them. Or if the in-stem OneUp kit has room for a CO2 cartridge. I'm prepared to be corrected on that.
Of course there's still #4, which is to say screwit and walk down the mountain when it happens.
Oh, and I almost forgot. The biggest problem I foresee with CO2 cartridges is that sometimes you have to attempt to inflate the tire in order to be able to locate the puncture from the hiss. Can you partially use a CO2 cartridge? Or is it all or nothing? Does that mean carrying at least two?
So, opinions? Suggestions?
Admin edit: Photo added for newsletter and social
