For years I used this type of injector for the sealant i bought in a gallon jug. I take the plunger out, close the valve, and then pour sealant into the cylinder. Then I insert the straw into the valve, open the valve, and inert the plunger. No mess, and it also sucks sealant out of the valve before tire removal.
I like it has a relatively long flexible hose and the blue valve also comes in handy when filling the cylinder.
The problem is, the plastic becomes brittle and leaks. Mostly where the tube connects downstream of the valve. Since I disassemble everything for cleaning, i can't seal it with silicone or something. It works for a year, but once it starts leaking, I need to buy a new injectors.
All my valves are Shrader (future may bring some Presta??). So I can't use one of the screw-on adapters like the Stan's syringe. I know the Parks TSI-1 exists. But I like a longer flexible tube.
So I want to buy one of similar type, but better quality. What should I look at?
