Best tire levers?
1.7K views 43 replies 30 participants last post by  kwijbyo187
#1 ·
After doing an 1800’ climb this morning and then flatting in the first 50 feet of DH, then limping home to barely make it to work on time — I threw a Cushcore Pro in the rear this evening AND a new DH-casing Highroller 3.
In the process, I broke my last Pedro’s lever. They’ve always worked very well for me, but eventually break. With the big insert, I’m thinking I need something a little more robust and with more leverage available. I got the tire on one side and then down to about 6” left before the Pedro’s broke. Had to use a screwdriver wrapped in a rag to finally get it on.
What are your suggestions?
#2 ·
Cush Core makes the best lever. It's not only robust, the fat bulb handle that fills your palm is what makes it special.
#4 ·
I will pick up a couple
And I want the Bead Bro! Have you ever found yourself using both hands, both feat, your chin, and a knee to get a tire on! I have!
But if its summer I heat tires uo in the sun, if its cold I place them in front of space heater. Gets them nice and gooey
#15 ·
Last October at ~10,500ft skirting the snow line heading for a mountain pass, 4+ hours from civilization my rear DD Maxxis flatted when a snapped spoke pierced the tubeless tape. Trying to unseat and fix that muddy SOB with the OneUp pump tyre lever took me an hour. Immediately added a Pedro's lever back into my pack.
That ride started just before sunrise and finished at sunset, I could have done without that mechanical delay :D
#7 ·
Tempted to search but can't be bothered. But I'll go out on a limb and assume you're one of the "I haven't had a flat in years so I don't bother carrying tools or a tube" riders.
So the obvious suggestion would be to carry tools so you can fix that flat and not have to walk out. Secondary suggestion - maybe gasp carry a tube for the rare instance when you can't get the tire to hold air?
Hey, you asked. 🤣
How far was the limp out?
#9 ·
Hey, you asked. 🤣
I totally own that I wasn’t quite prepared. I only had a Co2 inflator, and after taking the tire off last night, I found that the sealant was down to almost nothing.
The climb was all on a fire road , then a bit of hike a bike up to the start of the trail. The trail is quite rowdy, and the first half has a lot of sharp rocks. It is pretty much the only trail in which I’ve had flats in the last 5 years. I made it 50 feet.🤣
I immediately pushed back up and exited to the road, so at least I’d have a somewhat smooth surface to roll back down. The Co2 got me back to the road, but I had to roll about 3 miles and 1800’ vert back to my car on a flat rear tire w/ no insert.
The rim is fine, and I couldn’t find any significantly large holes in the tire. Sealant probably would have sealed it up, if it had been topped off.
#11 ·
crank bros speedier tire lever is the best portable one I've used
[the best are the big metal ones too heavy for riding with]
#12 ·
For carrying on a ride I prefer the Wolftooth levers. They include a couple other helpful tools like a rotor straightener, rim straightener, and a really good tire lever.
#16 ·
I have like 30 levers, including the Cushcore one and I still find myself using the Pedro's one every time. Every bike with in frame storage has a Pedros in it.
FWIW, you can break the Cushcore one. Back when I used inserts I broke at least two of them :LOL: I'm 100% sure that was a combo of poor technique and lack of patience.
I once had to use an old, rusty butter knife that I had found on the trail, collected to throw away and forgotten was in my backpack for who knows how long. It worked, not recommended.
#24 ·
Pedros or regular Park have always worked for me. Although I have snapped a Park lever - their plastic isn't quite as tough as it used to be.
For any of the plastic levers, I think they tend to get brittle over time. Best option may just be a fresh set of Pedros.
#32 ·
The only time being a Clyde is beneficial. Put the wheel on a blanket. Put the only deflated tire on the edge of a 2x4 and step on the rim. haven’t met a bead yet that could resist my tonnage.
Disclaimer - may scratch or damage rim, bend rotor, or cause personal injury. Only use this method after offending the neighbors with a copious amount of profanity.
#35 ·
Pedros, but I really like the new Park Tools TL-4.2 tire lever... wide, thin, but short tip profile. I've had times the Pedros lever will slide into the rim bead, damaging the tape, when levering over the tire bead. The Park Tools lever, based on its short and sharply angled tip, works better to grab the rim bead.
#38 ·
Probably right. I’m just going to get a couple more Pedro’s levers. Their plastic has just the right mix of strength to flexibility. They normally work fine for me on most tires, even DH casings.
My latest combination of a DH casing + a Cushcore Pro was a little too much for the old Pedro lever I had. Next time I deal with that wheel though, I’m going to use some plastic carpentry clamps to press the tire and insert in to the center in a few places. That should eliminate the need for quite so much brute force. I don’t know why I didn’t think of that before I broke my last lever…
#39 ·
I had a ton of tire levers, Pedro's is still the goto no nonsense lever.
Actually over the years I am learning to appreciate other things Pedros make over other brands.
The real test to a tire lever is Schwalbe tires on super tight rims.
#41 ·
I've tried metal core levers where the core didn't go all the way to the end and the plastic end snapped off. I carry multiple Pedros in my pack and one of these in case I need something I think won't break:
