many have asked how to properly set up a avid bb7 brake lately in the turner forum, here and in pm's so i thought id help out. as far as ive seen, this is THEE guide to gettin proper feel and modulation out of a very fine brake system and ive used it with superior success on aprox 200 bikes. this only works for the avid bb7 so if ya try and morph this onto another system, such as a hydro brake, i cant be held responsible for the outcome or yer stupidity. ive properly prepared for the creation of this guide with a case of four peaks brewing company's 6% kiltlifter scottish amber ale and a few hits off the crack pipe. so without further auh-dooo.....
1) start with clean or new pads. clean the rotors with alchohal and never touch with skin.
1a) rotors must be true to within .005" on a dial caliper or damn close to it.
1b) you must have avid speed dial levers for this to work. shimanos with inner adjusters are close but will never do the job as well. ever. get it? never! and yeah, i forgot 1a and 1b in the beginnin and wasnt about to re # the whole damn thing for the likes of you. so friggin get over it.
2) use locktite on all older caliper and rotor mount bolts, perferably blue 242.
3) loosen caliper adapter bolts slightly and rotate up in the direction of rotors rotation and tighten. 80 ip for you torque fans.
4) loosen caliper mount bolts slightly so caliper can move side to side.
5) back out red pad adjusters fully.
6) turn inner pad adjuster in fully then back out 10 indexed clicks.
7) turn outer pad adjuster in till it bottoms out on rotor. do not force this step. rotor should not move in caliper at this time but caliper may move slightly on its adapter.
8) tighten caliper mount bolts. 80 ip if ya like.
9) with a cable in yer lever and housing run to the caliper (all new or in good shape and at proper length ill assume) turn barrel adjuster in full.
10) if yer caliper has some miles on it, it might be nice to dab the cable pinch bolt with some wet chain lube, grease or anti sieze.
11) use a 4th hand tool to take up any slack in the cable and tighten the pinch bolt. 80 ip, see a pattern here? as in step 7, do not force this. if ya see movement in the acctuator arm, go back to step 5.
12) grab a handfull of lever and check for cable slack. there should be none. if this is a new cable/housing install, give it 4 hard pulls to seat and stretch everything into opperational position then go back to step 11.
13) back both pad adjusters out fully.
14) turn inner pad adjuster in about 4 indexed clicks, pull lever 3 times, spin wheel and check for rub. repeat this step till any rub is heard. once rub is home, back it out 1 click at a time till it goes away then 2 or 3 more for clearence. i go 3 most times.
15) repeat step 14 for the outer pad adjuster. with a ear close to the rotor, not that close dummy!, you should hear zero rub of rotor to pads.
16) lever throw should suit yer style. too tight? back out the outer pad adjuster 1 click at a time till feel is reached, not the inner pad.
17) now that both brakes are set and workin, see how 1 lever feels nice n stiff and the other feels like ass? no probs! thats just a good short front cable vs that long rear cable and all its housing compression. rectify this and modulation feel 1/2 turn at a time of the speed dial knob on yer levers. start with the front knob turned in to soften up the leverage ratio of said cable to match the rears feel. a 1/2 turn goes a long way so take yer time.
17a) see that little allen head on the back of the actuater arm? thats a preload adjuster for the spring tension on the caliper. turn it in to suit additional lever feel. i like mine tight baby! thanx to cuthroat for the memory check!
18) i like to trim my cable to about 2" so i can service and re-tune the system several times before replacement is needed. make damn sure it doesnt touch or get in the rotor and dont forget yer cable end.
19) take up slack in pad wear by repeating these steps.
20) now go ride and dig yer new brake feel!
wonderin if yer avid pads are old and dead? measure with a micrometer. pad material and backing plate should read no less than 3.00mm. i replace em at 25% or 3.25mm just to be safe. a new avid pad is about 4.00mm.
there been some good info on pad type lately. ill try and find it so we can include it here as a reference sometime soon.
you can start here.
and then go here.
you can start here.
and then go here.
