I'm running BB7 brakes on my Ebike with metal jacketed cables, and SRAM metallic brake pads. I added Shimano RT86 ICE rotors recently.
1- You have to cut the metal tab off of the inner pad, even with the caliper body to clear the alloy spider. You can get it out by pulling the outer pad first, then the inner one.
I saw one reviewer who spent an hour trimming the spiders. As the pads wore the interference probably came back! Just cut the tab.
2- For some reason I had to add a 1/8"spacer for the 203mm F rotor on an Avid 203F IS bracket. No idea why. The 180mm R was fine.
The thing I want to share is that with solid rotors I would get brake squeal under light braking due to the outer pad hitting first and the rotor would ring until harder braking pushed both pads against it. One click + on the inner pad would usually stop this. I haven't had to do that since putting the ICE rotors on. I'm thinking that maybe the ICE Tech bimetal rotors don't ring. Since Shimano only recommends the 203 rotor for cable brakes I wonder if others have experienced this?
