21 - 40 of 118 Posts
What's old is new again....that makes at least three mfgs with recent models that are going back to the future with alloy-lugged carbon-tubed frames. It's a proven-ish design, but unfortunately you are putting three material failure properties into one frame...the thinnest being an adhesive layer. Putting them under these peak load stresses is fairly new though. I'm trying to figure out why companies are going back to this design, and of course it is immediately obvious - it's cheaper. Printing lugs and connecting them with carbon costs a whole lot less that numerous mold designs and human layup. I have no doubt it will be sold as the greatest thing ever and better than everything else though.
If they are going to continue with this construction type, they need to figure out a way to incorporate mechanical interference at the joint fitting as redundancy to adhesive. That's a tall order though and they may as well go back to full carbon molds at that point.
Throw a few drywall screws in there and we’re good!!!
Looking at ATHERTON vs PIVOT photos, looks like the cable ports are in different locations. The Pivot has a lot less adhesive area on the down tube and Lub interface. I'm not a mechanic engineer, but I've glued a lot things in my life, maximizing adhesive area it always beneficial for longevity.
Somehow the engineers will find out a way to blame Kerr. I mean, has an engineer actually ever been wrong?
Actually I think engineers are the most likely to admit and allow for new data that indicates the need for improving a design. It’s the marketing department that would never admit it
What? Marketing is going to have to figure out a way to get them out of this situation. Broken prototype bike. Injured rider. I can't imagine that Pivot hadn't made the call to Pinkbike immediately asking to keep that broken bike off the front pages. If bonded lugs were so great they would have kept making bikes in the mainstream with that same technology after 1999.
I will point out that Kerr posted a video yesterday looking and claiming to be 100% uninjured.
What do you do with the rest of the teams bikes now? Pretty big confidence shake...
Parallel tubes are easier to pull out than tubes at an angle no doubt, always thought these pivot prototypes looked suspect, those are poorly designed lugs for fewer operations in the mill.
Raw aluminum on carbon is a big no no too, insta corrosion = de bond
Then you ship it around the world and beat the snot out of it without the "engineers" eyes on it. Pretty negligent prototyping.
I'm not speaking about this case in particular, but every single engineer I've known in person has been unwilling to allow that anyone else might have useful information about a problem that could contribute to a solution. They are the lone problem solvers and everyone else must follow their direction to implement their solution.
Race bikes ride the knife edge of weight to strength ratio. It happens, and it used to happen, and it will probably continue to happen. If you want to win you have to balance on the edge.
That said I recall the era of the thermoplastic frames (GT, mantis, etc) and how they failed due to the inability of the lugs and tubes to bond correctly. But also vitus bikes were able to make tiny aluminum tubes stick to aluminum lugs with small amounts of overlap and they would last for way too long, until the Aluminum was way past its prime.
I don't know it seems a little dramatic to me. It's a prototype. They're probably not even worried about this. Prototypes are given to racers on purpose to find out their weak points and eliminate them. They'll probably say this is a good thing and proves that they're doing the right thing.
Wow - I wonder how then a group of 10 engineers working on a design project might ever get anything done?
Have you ever heard of a "design review"? I wonder how any "engineer" ever deals with that?
It's stuff I read on here that makes me laugh at how much every person takes for granted in their daily life not knowing sh!tshow that goes on behind the scenes to get there. There needs to be a reality TV show on Netflix or something #engineeringawareness
One major difference between Pivot and Atherton is the lug to tube interface. Pivot is a single wall connection and Atherton is a double wall connection. Double wall allows twice as much surface area for bonding.
Please, oh please, show me a carbon fiber bike with a threaded BB that doesn't have aluminum bonded to the matrix. This is common in almost every bike made today.
Pretty much anywhere in a carbon layup that uses an aluminum insert has a layer of fiberglass to isolate it from corrosion. It still happens though. Your dropper is isolated by the anodize until it wears or corrodes and gets stuck.
