I just did a calculation, comparing the attack angle for a 26" wheel with a 2.2 tire and a 29" wheel with a 2.0 tire (which is the setup I measured).
The angle of attack is the angle between the vertical line from axle to ground to the line from axle to bump.
The difference are as such(all bumps are square edge):
4" bump: 26"- 45.2 degrees, 29"- 43.4 degrees, difference - 1.8degrees
6" bump: 26"- 56.2 degrees, 29"- 53.9 degrees, difference - 2.3degrees
8" bump: 26"- 65.9 degrees, 29"- 63.1 degrees, difference - 2.8degrees
These differences do seem small.
Also, for suspension bikes, 26" bikes will have more suspension and the whole point of suspension is to reduce the attack angle by allowing the wheel to pick up and roll over an object. Try rolling over a curb with a 29" wheel with no suspension, and then do the same with a 26" wheel with suspension (without picking up the front-end).
Wanted to get some feedback on this forum regarding this.
I'm not trying to say 29" wheels do not have any advantages on a suspension bike, though I would like to understand the advantages from a scientific standpoint. In other words, without emotionally charged perceptions, which I know is asking a lot since we are so attached to our perceptions.
