Anyones fatbike that weigh less than 26lbs?
5.6K views 21 replies 19 participants last post by  wwfatty
#1 ·
Hi just wondering if folk have fatbikes that weigh less than 26lbs in weight, if so pictures and build please.
Cheers
#13 ·
I was doing the math on mine the other day, the CS-197 frame was around $350 and the total bike cost is near $3-3.5K, which for the weight is excellent. This includes building my own rims though and so on.
#12 ·
Of course. 22.something and it's not the lightest you'll see by far.
Builds are the same as any other weight weenie build, carbon frames, bars, posts, light brakes with lightweight rotors (work great in the winter), next cranks, sram 1x11 or 12 setups (lighter than equivalent shimano by a good deal), light pedals, etc.
The key is usually the wheels, that's where you get the most bang for the buck and can get something way lighter than a stock bike. Many fatbike rims are 800-1000g or so, tubes of this size are at least a pound often times, rim strips and lower end tires can create a massive amount of rotating mass. Good carbon rims like Light Bicycles, Nextie, HED and others can save decent weight, weighing in at 400-550g for the lighter models, and most carbon rims tend to be far more "tubeless compatible" than most of the aluminum rims, so that helps. Then you can use some lightweight spokes (don't really need thick ones with ultra-stiff carbon rims and their wide angles) and a good hub like DT or Hope.
#18 ·
My Voytek weighed 23 lbs. 4 oz. when I put in on my bike shops scale after they installed my Lauf fork. That was with the 27.5 wheelset on it, but the fat wheelset is only about a pound heavier each, so that would still keep it below 26.
