Forbidden Bikes Introduces eDruid and eDreadnought
This one caught my eye
Forbidden Ebike
Id be all over a long stroked E-druid🤑
Forbidden Ebike
I rotate 5 chains. After a muddy ride like that, I replace the chain - even if there is enough wax left on the rollers, the rest of the chain is covered in grit, so will wear the drivetrain. If it's merely a bit wet (but clean), I might leave it on, or top up with a drip wax. Since using the Silca Endurance Chip, the wax does indeed seem to last longer, though it's been unusually dry here in Wales so I'm not sure how much difference it makes in typical UK conditions.Does waxing hold up in wet weather?
This is what my bike looks like 9 months of the year.
Got it, thanks for the info.I rotate 5 chains. After a muddy ride like that, I replace the chain - even if there is enough wax left on the rollers, the rest of the chain is covered in grit, so will wear the drivetrain. If it's merely a bit wet (but clean), I might leave it on, or top up with a drip wax. Since using the Silca Endurance Chip, the wax does indeed seem to last longer, though it's been unusually dry here in Wales so I'm not sure how much difference it makes in typical UK conditions.
Of course, you shouldn't be using a dirty chain with typical lube on it either, unless you don't care how fast you burn though components. So if it gets muddy, you should be removing the chain to clean it, in which case you might as well use wax (with all its other benefits) rather than some horrible drip lube. See ZFC for more details.
I begin by stripping and waxing about 5 chains, and put one on my bike. In dry conditions, I can get several rides on that chain before it needs either a top up of drip wax or removal from the bike. In muddy conditions, I might only get one ride on it before I remove it, rinse it with boiling water, dry it, wrap it in a cloth, and store it somewhere. When all 5 chains have been used, I rewax them in one session. See ZFC for details.Got it, thanks for the info.
The slight problem, is that this just isn't a one off sort of thing around here. Its just... how it is from about October, until about June. I see you're in Wales. Do you actually replace the chain with a different one, and then clean/re-lube after each ride?
Totally possible, but that does seem like work I'd have to adjust to. Plus 5x chains at once is a bit of a purchase.
Do you dry them before rewaxing?One trick with waxed chains is that before I remove them to rewax I full on spray them with water until the water runs clean. Then they are ready to just drop right in to the wax.
I usually grab the nearest shop rag and wipe them off. But it's very hot here and the boiling in wax gets rid of moisture anyways so I don't put much effort into it.Do you dry them before rewaxing?
The hardest part about the wax system with multiple chains is preventing them rusting between waxes.
Just laucnhed on PBWas the annocement suppose to be today?
Is that CAD? Pricing is TBD on US siteWelp with a pricing range of $15K to $11K- that puts me out of the running!
Im sure it will be an amazingbike to ride
Bike manufacturers pay less than $1500 for the rest of the bike outside of the frame.I really wish more brands did frame-only options. I want to move over the good stuff off my hardtail but ÂŁ7800 for the base model, plus more to upgrade the shock to Ultimate, is just daft when I won't be using most of the parts. I was looking at the Ari Timp Peak 2.0 as they do framesets, but just the frame would cost ÂŁ6000 ($8,000 USD) after tax and import duties in the UK.
Propain does frame only for all bike but emtbs, maybe they'll change that some day AND get rid of headset routing. Otherwise I agree, more frame only options would be great. I don't even mind the lower offset costs to completes, I find it so wasteful for a box of parts I'll never use or take the time to sell.I really wish more brands did frame-only options. I want to move over the good stuff off my hardtail but ÂŁ7800 for the base model, plus more to upgrade the shock to Ultimate, is just daft when I won't be using most of the parts. I was looking at the Ari Timp Peak 2.0 as they do framesets, but just the frame would cost ÂŁ6000 ($8,000 USD) after tax and import duties in the UK.
Yeah, there isn't much demand for no-name own-brand take-off parts, or even low-end branded stuff, and it's a faff selling lots of individual low-value bits.Propain does frame only for all bike but emtbs, maybe they'll change that some day AND get rid of headset routing. Otherwise I agree, more frame only options would be great. I don't even mind the lower offset costs to completes, I find it so wasteful for a box of parts I'll never use or take the time to sell.
