I recently replaced my 500 with a 501. Left the factory installed white grease undisturbed, gave it an ATF oil bath, drained, and installed in the hub body. Seems to work fine, but maybe a little noisy, like it's not really happy with the ATF because it's thinner? It also seems more sensitive to shifter alignment.
I'm thinking about trying some 75w-90 gear oil (which is actually the same viscosity as 20w-50 motor oil). Maybe give it a gear oil bath, let it drain, pack in some white grease, then install?
Anyone have any tried and true methods, or lubricants for these things?
