I seems that I am adding air to my rp23 every week to ten days. I don't think that this is normal. Any help is welcome.
When you attach a pump, it typically lowers the shock psi by about 5 psi just to pressurize the hose and gauge. This makes it seem like the shock leaked the 5 psi.Mai said:09 shock 30psi
...Not sure what you mean. I check the psi with the gauge on the pump and bring the psi back up to the desired amount.
Are you ridding it in between? Shocks are high pressure systems. If there is even a small leak, it will blow when ridden.Mai said:I seems that I am adding air to my rp23 every week to ten days. I don't think that this is normal. Any help is welcome.
Exactly.gmcttr said:When you attach a pump, it typically lowers the shock psi by about 5 psi just to pressurize the hose and gauge. This makes it seem like the shock leaked the 5 psi.
good post..managedenemy said:I just read the section on how to use the shock pump on the fox web site and it said that you could in fact get a psi reading of even 20 psi lower from the pump itself filling with air so if it rides good I would not worry about it. Go to forks or something then tech center and look around for how to use shock pump under setting sag.
That might be true on paper, but in practice I have never used a shock pump that decreased the reading by 20psi.managedenemy said:I just read the section on how to use the shock pump on the fox web site and it said that you could in fact get a psi reading of even 20 psi lower from the pump itself filling with air so if it rides good I would not worry about it. Go to forks or something then tech center and look around for how to use shock pump under setting sag.
That was the problem! 4 turns on the loose core. I did order the seal kit for later. Thanks eveybody for the helpLDH said:pull core and add a few cc's of oil to the air chamber first before you do anything else.
