1,021 - 1,035 of 1,035 Posts
Both, 3.0 front and 2.8 rear.
Now have 2.8 minions on both ends though.
Hi. What tires are you running now? I am running DHF and DHR on my 29 wheels, and am considering going 27.5+.
What rims do you have? I could not tell from your pix. I have 29 Roval Carbons on my 2016 E29 and they go out of true when I ride downhill trails (go figure ;- )
How many cm do yo have between the back tire and rear triangle of the frame?
6mm on both sides and upper says arch, 5mm to bottom arch (between chainstays).
from all i've read i understand that 6mm is the minimal recommended clearance, but have seen many here ride with much lower clearances.
i have not ridden in mud yet, muddy rides are not so common here, its either dry and loose (most of the year) or non-ridable goo.
Just an update after some time riding my converted CANYON SPECTRAL 7EX with 2.8 DHF+/REKON+ on 30mm id rims.
Works great for all tails I ride. Holds well through corners, drop offs and rock gardens.
Just got a first mini-DH session on them - they've been amazing! super fast and confident, despite the terribly loose conditions. no clearance issues at all (had some doubts).
I find the i30 rims to be acceptable with these tires, but you really have to go i35 or wider for the full experience. Could not get comfortable with pressures lower than 13-14psi, actually punctured my rekon at the bid(!!) at around 10psi, but riding was pretty rough.
Made a cool video for that ride - so you can get a feel of what the conditions were like
https://vimeo.com/241383473#t=15s
