1,001 - 1,020 of 1,035 Posts
Discussion starter · #1,001 ·
Hello guys!
I'm itching to try a 27.5+ conversion with my 2016 Kona process 111. Thing is I want to go with a wider rim for the WTB trailblazer 2.8 tire.
My concern is the limited rear end on the bike.
- do guys think that the Asym i35 would work?
Thank you
It's works perfectly. The Rekon 2.8 is primo with an i35 size rim on the 111.
Sent from my SPH-L720T using Tapatalk
I'd really like to try converting my Kona Big Unit...even if I can only get a 2.8 in the back. I'd be in about half the cost of a new bike with wheels and suspension fork though that's not required since my rigid fork will handle 29+. But...might be worth the new fork in Boost 110 and wheel to match.
I saw someone converted a Kona Unit...anyone have luck with the Big Unit?
On One Codeine 29 S + Fox 34 (@130 mm travel, -1.5 headset)
Front wheel: Dartmoor Aircraft (i45) + Maxxis Minion DHF 27.5x2.8
Rear wheel: WTB Asym i35 + Schwalbe Nobby Nic 27.5x2.8
No rubbing, enough clearance to ride it.
Nice bike. Just wondering what kind of clearance youre really talking about. I currently have a parkwood, and have been toying with swapping it out for a codeine if it goes back on sale... I currently ride NN2.8s on i45s, and it barely clears the hardtail. Think theres enough room on the codeine? Thanks for any info.
Almost 1 cm each side between the tire and the seatstay.
WOW, thats a lot more than I was expecting. I'm working with only about 5mm on each side, and I dont see the NN getting that much bigger from 35 to 45mm rims. Thanks for the info.
