701 - 720 of 1,035 Posts
Discussion starter · #704 ·
You've got the right idea but you need to make sure that you're making this measurement 30-31cm from the rear axle as this is where a 27.5+ tire will be at its greatest width. You'll probably need to remove the rear wheel to make this measurement in the correct location.
I went home and double checked my measures and must admit that my current setup has the widest spot of the tire at 33cm from the center of the axle. It's a Nobby Nic 2.8 on a i36 rim. Others I have measures are different than this. To be safe, measure between 31 and 33cm from the center of the axle to get your measurement.
On my bike the chainstay distance is no different at 31 vs 33cm, but other bikes might be.
Sorry for any confusion.
Sent from my SPH-L720T using Tapatalk
I see. So now that you know it's 33cm at its widest spot on the tire, now you can measure the width across the seatstay and chainstay at 33cm from the dropout. And it should be minimum of 90mm (80 for tire width +5 on both sides for mud clearance)
Discussion starter · #707 ·
Mine is 80mm and is just fine on clearance. 90mm is a little extreme for a minimum.
My NN is 2.7 I believe at its widest.
Perfect! Thanks guys, now I can go measure up a few frames. The OP is on to something with that marlin frame. I've seen those frames on eBay for $100 (or less). If the + tires fit, could make for a fun and cheap project to play around with.
On facebook, I saw a guy mount NN 2.8 to a 2008 gary fisher paragon 29er (those are cheap too)
It'd be nice to have a sticky thread in this forum which contains a table listing 29er frames with the necessary measurements and a list of rim/tire combos that worked for that particular frame. It's nice to know that some of these frames are not too expensive either.
Man this measurement thing is difficult. You are saying that from the center drop out 30-31cm down the chain stay and seat stay I measure the width at that point across the frame?
Discussion starter · #714 ·
That is correct. But to be safe, i would measure between 31 and 33cm from the center of the dropout to account for different tires.
I've only got 76.5mm between the stays on my project bike. Is 2-3mm on either side of the NN 2.8 enough for non-mud riding?
So wanted to get the PonyRustler but all sold out.
Got a crazy good deal on a Horsethief today and would like to go 27Plus on it.
Lots of room between the forks but not as much in the back.
Could I go wider in front? like 3.0 and 2.8 in the rear?
It has 29er 2.35 NN from Salsa, need to find my calipers.
A WTB Trailblazer 2.8 will fit in that Horsethief rear triangle on a Velocity Blunt 35 rim. A Nobby Nic 2.8 on the same rim will not.
