41 - 60 of 1,035 Posts
Am I reading the chart correctly? It looks like the trailblazer 2.8 is measuring narrower than a 29X2.4?
That is correct. The tire is designed like many fat tires, with more casing than tread width for maximum air volume not maximum contact patch. Continental tires are typically the same way as are a host of other WTB models. Problem is in a rock strike, things that make it past the tread will find the sidewalls. I prefer my tires with more tread than casing (even if its very close like the Vee Trax Fatty with only a couple millimeters difference).
The WTB's tread is only around 2.25-2.3, but it's casing is much wider. It's not intended to be like a 2.4x29er, rather it's intended to put a big volume tire in place of a 29er tire/wheel.
Not only that but the casing is narrower than the tread as well. Appears to be off a bit.
lol. Have another look. Every single 2.8 casing number is wider than the tread number. Which is exactly how this tire was designed.
2012 Rumblefish works great
Nice clearance using wide lightning wheels, trailblazer tires front and rear. Wouldn't want to go any larger with rear tire but I already want the Nobby Nic 3.0 in front.
I also have wide lightning 29er wheels using an Ardent 2.4 in front and the trailblazer is not mean enough in front for me.
Discussion starter · #46 ·
What pressure are you running up front? I was skeptical at first, then I dropped the pressure to ~10-12 psi and it completely changed the handling of the tire.
If you haven't tried low psi, give it a shot.
Discussion starter · #49 ·
^^^Nice Farley 8 dougmint!
Two more full sus 29ers worth mentioning and possible candidates with nice slack geometry and already all-stars below!:
https://www.transitionbikes.com/2015/Bikes_Smuggler.cfm
Banshee Bikes » Phantom, 29", Trail, supercharged mountain bikes for sale
These are possible options, but have you actually fit the B+ tires in the frames? We want to make sure we test the setup before we toss them in the thread.
If you have not, hopefully someone with a Smuggler or Phantom will help us figure out if they will work.
I hope they do, they are sweet rides...
How's about if you think that a fat, B+ front wheel leads to slow, sluggish and cumbersome handling?
Discussion starter · #51 ·
With the right rim, I would say that the sluggish handling is sorted. I don't feel my front is slow or sluggish at all. But I also have a i45
Discussion starter · #53 ·
Nice Has anyone seen 27+ on the Remedy 29er?
I don't have a Phantom to test fit B+ tires on, but there is a B+ thread for Banshee Primes and Phantoms (linked below) where people report 81mm of clearance on the chainstays and seatstays for both frames. Nobody posting there seems to have tried B+ but there are pictures of Phantoms running 29+ Knards and Chronicles in that thread. I'd be stunned if everything smaller than a VTF didn't fit.
http://forums.mtbr.com/banshee-bikes/b-prime-phantom-lets-talk-about-939538.html
I don't believe boost is bogus because you can get a 2.8 that's designed for existing 29ers to fit the rear but probably not 3.0 or 3.25 which you would need a wider "boost" front and rear for.
