2022+ Element Build Thread
128K views 522 replies 92 participants last post by  andrewbn42
#1 · (Edited)
It seems as though this bike has gained alot of traction with a bunch of different types of riders. I imagine folks will be upgrading their stock builds and building some either super light or super burley bikes. Hopefully this thread catches on and I am interested to see what you people are coming up with.
For what I ride in the front range of Colorado, and how I like to ride, I found that the Rekon tires and 2 piston brakes that were spec were not going to cut it, but I wanted to keep the bike pretty light, so I added some weight weenie items to balance the bikes weight. It's still not light, but it's light for me.
2022 Element C50 Large
Added:
1. Hunt XC Wide Race wheelset
2. Specialized Butcher T7 29x2.3
3. Specialized Eliminator T7 29.2.3
4. Cushcore XC rear
5. Tag T1 carbon handlebar (30mm rise, 780mm width)
6. Renthal Apex 45mm stem
7. SRAM G2 RSC brakes
8. Canecreek 40 zero stack headset
9. Shimano XT trail pedals
10. Specialized bottle cage x2
11. DMR Death grips
-Total weight 29.01lbs
-My weight: 185lbs with gear
-Shock setup: 245psi, 25% sag, 6 clicks from slow on rebound
-Fork Setup: 92psi, 2 token, 7 clicks
  • Like
Reactions: mrwulf
#126 ·
Pretty sure you need to run the eyelet bearing no matter what.
You might be able to fudge it with some creative spacers, but I wouldn’t.
#129 · (Edited)
Anyone else really enjoying the Marzocchi Z2 fork that came with the C30 build? I've done some tasteful upgrades around the bike but left the fork. It's simple, set & forget, and has an open bath design that I find to perform well despite it's simplicity. Decided to keep it.
Other upgrades include XTR crankset, XTR shifter, OneUp carbon bars, 40mm stem, Slate TRP Evo brakes... ready for the snow to melt.
#131 ·
This is mine as is stands. Its a replacement for my Spur which my other half is having, build up with her bits & I’ve transferred my parts over.
I was between the L & XL on the Spur, so this as an XL is ideal in the slack setting (which is a lot slacker than RM claim).
All indications are itis just as good as the Spur, but a little more muted, due to no flex stays, which both have their benefits. I expect this will also be my most ridden bike. 🙂
#133 ·
I’m probably the opposite in that I’m more trail than XC, but I do like big days out & I don’t want to not ride fun stuff, due to sketchy, old school geometry.
My angle measure puts the HA at 63.8 degrees in the slackest setting. I will measure the BB height also, as I suspect that will have dropped due to the HA & it’s probably steepened the seat tube angle also.
No complaints though - I am a fan of super light, short travel bikes with aggro geometry :)
#149 ·
After about 10 rides with the new Pike Ultimate 140mm fork, I can say this fork has transformed the bike. It handles so much better than before. Running a ZS bottom headset cup, Position 1 (slack). The stock Fox Performance Elite 130 was garbage in terms of performance, and I could never get on with the handling of the bike with that fork. I was seriously contemplating selling the bike before switching to this fork. Now I'm happy.
#154 ·
RideIt above is right, you're better off with the new Float X.
If you do choose a DPX2, maybe because it was inexpensive on Marketplace or somewhere else, then I've run this tune with great success:
- CM, LRM, Rezi A F M+
#155 ·
Cool to know that it’s possible to get a decent tune out of a DPX2, I was never really happy with it on a previous Gen instinct.
#156 ·
The DPX2 worked well to achieve a feeling more akin to a trail bike, with really good mid-stroke support and more consistent damping. You're right that in longer travel applications it was more finicky to tune well, but on the Element it was a great match.
#159 ·
Yes, by far replaced the wheels first, because you will also get a performance upgrade out of the bike. The stock wheels are rather flimsy but the bomber fork will operate completely fine for XC needs; if you upgrade the fork you'll pretty much only get weight savings as the performance is good enough.
#160 ·
Set this one up to be kinda XC. Wheels are chonky, but the light ones are being repaired and should lose 3-400 g from frame. Hoping that with light wheels, foam grips, and xo1 cassette it will be sun 25lbs.
Does anyone else think that the steepness of the seat tube angle is measured oddly? I can get the same saddle position at sag as my old blur 3 tr with a 120 fork on both, and that bike was more than 3 degrees slacker. At my saddle height that should be more than 4.5 cm forward, which is twice the range my saddle can adjust
#161 ·
Anybody 6’6” running an Element here. Haven’t been able to find a XL around here to throw a leg over. I like the numbers as it’s a little longer and a little more stack than my XL Specialized Chisel. Manufacturers don’t seem to want to make an XC leaning bike in the XXL variety. The Tallboy comes close but is much more a trail/all mountain type chunky frame build. Randomly ran across a large Element the other day and it’s just the thing I’m really looking for.
#162 ·
I can't answer your question, but at 6'6, you'll find the fit a bit better with a 60-70mm stem. Our size range for the XL tops out a 6'6, but you might find the stock 50mm stem a touch short.
#163 · (Edited)
This is my build. '22 MY C50, L frame (loved the color). Waiting on a carbon wheelset. Till then, 35ID Spank Oozy 365 will do it.
Swapped calipers to 4pot SLX & dropper to a 200mm PNW. Oneup carbon bars & 45mm Spank 350 stem. XCadey PM on 170mm cranks (thinking of trying 165s, I do strike a bit). About 300mi on blue trails, all @ neutral (3) position. Did not try a slacker/lower spot yet (perhaps with the 165 cranks?).
Running Dissector 3C 2.4WT Front w/ Rekon 3C 2.4WT rear (both mildly used). New wheelset + tires were moved to the bike I had the Spank wheels on.
Flirting with the idea of 140mm, but unsure if I should just up-shaft the 34 or get a '23 Pike.
#168 · (Edited)
For those of you considering an XC-ish build of an Element, here's what I've been running this season:
-Sid Ultimate 120mm fork
-Industry Nine Ultralite 1/1 Wheels
-Cane Creek Hellbender 70 Lite
-TRP Slate T4 Brakes
-SRAM Centerline X Rotors 180/180
- I9 A35 Stem
-One up Carbon Bars
-ODI F1 Vapor Grips
-Vittoria Mezcal/Barzo
-Stock Fox DPS Shock
-Wolftooth Resolve Dropper 150mm
-WTB Ti Volt Wide
-SRAM X01 shifter/derailluer/cassette
-Sigeyi Power Meter
-Crankbrothers Candy 3 pedals
Bikes weighs in at 25.5 lbs with pedals.
I unintendedly ran the geo of a 140mm fork (had the 10mm spacer headset) for a few months. Rode great. I'd have zero qualms about doing it again with a bigger fork. I also love my Pike on mine when I set my element up in trail mode.
Also 165mm cranks are incredible. I don't think I can go back to 170mm+ again.
Really happy with my Element. But after about 300 miles ridden the shock is still losing a lot of oil/grease every ride. I'm wondering if this is normal or the shock was leaky from the start.
Yeah, pretty normal. They sometimes overstuff their products with grease out of the factory and you get that. You're almost coming up on the 50 hour mark so you could pull it soon and do a quick air can service to see what's going on.
#164 ·
Just picked up a C30 and I'm really excited to build it up but I have never dealt with a press fit bottom bracket before.
After looking at RM website for tech specs i believe this bottom bracket will work for the frame with the e*13 xcx race crankset:
E*Thirteen (BB92 e*13 / 30 mm )
Can anyone confirm, I saw a few XCX race cranksets in build list on this thread but didn't see this bottom bracket.
Thank you!
#171 · (Edited)
Shorter offset = longer trail = more stable.
Longer offset = shorter trail = more maneuverable @ low speeds.
Wheelbase is not linked to shorter or longer offsets per se, or at least AFAIK.
If you like "steering" your bike more, perhaps the 51 will work for you and make the bike "sharper" @ switchbacks & technical climbs.
If you like leaning the bike more to go faster down, your trails have upkept berms etc the 44 (shorter offset) is superior, and more or less this is what RM thought would suit the Element's Geo better, but that doesn't mean it is the only way.
#172 ·
I’m having fun building up my C30… but man it’s almost like Rocky Mountain tried extra hard to make the stock components super heavy.
I get stock components are heavy, but some of these are like 100-200 grams heavier than the other stock components I have laying around the garage. The rear wheel with everything on it, 3 kg, LoL Wow!
it makes taking weight off the bike fun and easy.
#173 ·
Although you can definately shave off some bulk, I don't know where RM "tried" to make things heavy...it is just the nature of components AT THE BASE PRICEPOINT.
The rear wheel out of your example, they use a WTB i27 with entry shimano hubs and whatnot, but it is just above 1kg - pretty typical (front is like high ~800gr, again, typical for OEM wheels).
The rear cassette is about 600gr, cause all steel Deore and 10-51T, but even if you were to go XT on cassette & rotor etc, you would save 130+70 ~ 200gr altogether.
The rest is tire (about 1kg), valve stem, sealant etc...
Yes, you could find a 300gr lighter wheel, and mount a lighter tire (with compromises @ traction and/or protection) etc, but it is no more fun or ea$ier than with any other base build, i.e. the typical money pit. My 2c
