20" Mongoose Kong
27K views 68 replies 28 participants last post by  Hauntzl
#1 ·
My daughter's 9th birthday is in a few weeks, so I've been shopping for a fat bike for her. I looked pretty hard at the Mongoose Massif, but then I saw the Compac and Kong online. I ended up buying both the Compac and Kong figuring I'd compare the two in person and return one. It turns out that the two bikes are almost identical (same frame and components), but the Kong has drilled rims and much better tires. The Compac's rims have no lightening holes, and the tires are lower profile and much stiffer. My bathroom scale reads the Kong being about 4lbs lighter (36 vs 40lbs). I took a couple pictures of both to show the differences in the rims and tires. I never assembled the Compac, just removed it from the box to weigh it. I'll be returning it later this week, and keeping the Kong. I've never been so excited to give a gift before!
#36 ·
cool, i am not too worried about suing it on snow...for now....
can you give me the details on the mods you did? which parts I should be buying etc.
right now my boys are coming from a fixed gear bike and they need some choice but i do not want to overwhelm them.
does anyone make a similar bike in an 18" rim rather than a 20"...in the same price range?
#37 ·
I had some cranks made so I could run the 22 tooth. I also had to run the riser bars as upside down as drop bars because the front end on the bike is really high and I needed a shorter reach. It terms of upgrades if you can switch in aluminum bars, and seat post it would help. The seat is also very heavy. The only other place I would bother to spend money is in the tubes. They are pretty heavy. There are lighter ones out there. The rest of the bike is actually very well done. I have not seen an 18" fatbike of any kind out there. At his small size I wish there was a great 3" tire bike out there to lighten things up a bit. One thing I am keeping an eye on is the shifter. My son keeps shifting it by accident. If needed I will go to a trigger of some sort, but I suspect he just needs to get used to it.
#49 ·
There are a couple reviews out there that also say around 30 lbs. I think they are by "twowheelingtots" and "mountainmama." I emailed the owner Ian asking about using a smaller chainring on the crank. He said the one that comes on it is a 40T but said it could be swapped out, which I assume means the chainring is bolted on, not riveted, and he did not mean you have to swap the entire crank. Ours should be here by the end of the month and I can let you know for sure. It is also a freewheel on the back, but it can use the shimano mega-range cassette to improve the gearing a bit.
#50 ·
Hard to tell in the picture, but sure looks like the Kong crank, which was one piece of heavy steel with no ability to change. And the 11/34 mega-range is what I put on my daughter's Kong, and it still wasn't enough. My daughter is a beast, and we tried to use it just riding on fairly flat powder, and the gearing was just too high. The only options I could find were trials cranks, and they were half the cost of the Kong. So ended up getting her some 24x2.4" tires for her normal bike, and it worked great, as long as she was not first on a powder day.
#55 ·
It's normal head tube for 1 1/8 straight steerer. External cups. Nothing special about it as for normal frames there is only a couple standards. External 1", external 1 1/8", integrated 1 1/8, tapered, or 1 1/2 straight (cannondale only I think).
It's not a threaded 1" steerer so that makes it 1 1/8 external.
Headsets are the easiest to figure out though people over think them.
I am trying to figure out why you want to take a 190mm spacing frame and make it skinny tires. Can create the same bike using a 26" MTB frame.
Btw the bike is NOT the size of a 24" bike. Total tire diameter is that of a 26" MTB. So trying to build a MTB out of this frame you need to address it as a 26" bike otherwise bottom bracket is going to be really low, major pedal strike problems.
Sent from my XT1565 using Tapatalk
#56 ·
It was in the morning a couple like this: Mongoose Massif 20 " 7 Speed Boys Fat Tire Bicycle All Terrain Mountain Bike New | eBay
It was a couple for $50 each from China... but It is gone, only there are now these expensive ...
It is important that about the height, but this was a 20" wheel size not 24",... 190mm rear hub in a 20" wheel? ok, I don't know much about Fat Bikes
For a little 6 years old boy that is growing it was a good idea take that little fat bike to convert to an MTB to destroy in rough terrain, but it sold out
I will continue looking for 20" bikes on eBay, there are very few in my city
Thanks for all the information
