Converting a old Stumpjumper from 3x9 Sram X.7/X.9 w/ Shimano M542 cranks to a 1x10 Advent X setup. My current chainline is in the "good" range I measured around 47-48mm. If we count the cogs on the cassette as #1 being the 48t and #10 the 11t the chain lines up with the #6 cog biased towards the smallest cogs. I have two spacers on the drive side of the BB. Since I'm a old plodder on the trails and use my big cogs more than the little cogs I'm debating if I should try removing the spacers and line the chainring up with the #5 cog. The reasoning is better chainline for the big cogs I tend to use more. Any reason not to make this change? I can pedal backwards in all of the gears with no issues right now. Will I start dropping the chain in the 11 tooth if I move the chainline in further?
