142+ Explained Graphically
1 reading
37K views 37 replies 22 participants last post by  skiwi
#1 ·
This made it easier for me to understand the new "standard" ;)
#7 ·
Just as we suspected. To swap between a 142 and a 142+ hub will require derailleur adjustment.
Ugh. Specialized really needs to step up and offer the DT internals hub for sale.
For those (tls36) that haven't seen this here is the info page at Syntace who developed this standard.
http://www.syntace.com/index.cfm?pid=1&pk=1314
Scroll down for a list of compatible hubs.
Short answer - Yes Hope Pro 2 and Chris King can be converted.
I'm going to wager that the SX Trail is a standard 142 and NOT the Specialized proprietary 142+.
Cheers!
P.S. Huge THANK YOU to Epic29er for posting this great illustration of what this new standard really means and what Specialized has done with it to be a real pain in our ass.
#8 ·
I'm not even going to use Specialized hubs, so it looks like the standard 142 will work for me. Don't want to deal with the derailleur adjustment. That is disappointing because I'd love to get a set of the carbon Roval's for a race set-up but due to the required adjustment, I'll be getting a few sets of Stans.
#14 ·
question for the experts? can you put 135 (5mm QR) end caps on the 142+ hub negating the x12 standard? I wonder cause for single speed hardtail this would be pretty sweet. more triangle in hub, and really cassette spacing on a single speed is irrelevant
#15 ·
I believe the Hope Pro 2 adapter is available now. When I talked to King back in November though, they told me it would be mid-summer before the King 142mm adapter kit would be available.
I'd love to know how much of a difference the 2mm makes for wheel stiffness. When I talked to the guy at Specialized CS he made it sound like it would be a dramatic improvement. I personally find that a little hard to believe. I'm sure that it is incrementally better, but I'm not sure that I'd be able to tell the difference personally, especially when I'm using Crest rims which aren't going to be the stiffest to begin with.
Granted, I have the 142+ hub (non DT internals) at home and I'm not spending the $$ to build it up - guess I'm not that curious...
#16 ·
Turner, I'll let you know how they are. I have a crest rim sitting in the garage that I'll be built up on my 142+ hub. I will have the crest set of 142+ and the 142+ carbons. I converted a set of ztr crest wheels to 142 for my sister and will do a head to head comparison between the two on the same trail with the same tire/pressure. Only problem is we just got 21"+ of snow yesterday and the test may take a while.
#17 ·
i tried swapping out the end caps between my roval carbon 29ers and the aluminum roval 29ers both use the dtswiss internals... i could not get it to work, if anyone gets this to work, please let me know
on another note I have converted the roval aluminum 29ers that use the dtswiss internals to 142 with the dtswiss conversion kit
#18 ·
So, is a rear 142+ wheel convertable to fit into a standard, 135mm frame? Easily?
I ask, because I'm looking at getting a new Epic, but the models I'm looking at (non S-works) come with the 142+, but I'll be using a lighter wheelset and won't have any use for the stock wheels (therefore I would like to sell them).
#19 ·
It really depends on the wheel. The conversion from 142mm to 135mm requires a different axle for the hubs that I have seen. Most hub manufacturers seem to be offering the conversion (I9, Hope, King sometime this year, DT Swiss) - I'm guessing there are more, but these are the ones that I was specifically researching a few years ago.
#21 ·
My I9's converted no problem new shaft and caps. I guess there's a reason why they cost alot at first. It wasn't even that expensive for the shaft and caps.....To bad they clash a little on color. Green spokes with brown hub on a flow yellow frame.. I'll have to go all brown when I have to money for some new spokes...
#22 ·
My issue is that I want an Epic 29er (either the Expert or Evo R), but I want to upgrade to either the cabon Rovals or Stans Podium MMX before even getting the bike.
So can someone smarter than me explain what I should do, if the shop won't give me a decent credit (if any at all) for the stock wheelset? :D
They will never be used, so I would want to sell them if not (to offset the cost of the upgrade), but I'm assuming the market would be very slim given the 142+ style rear hub, correct?
#23 ·
chauzie said:
Why does S even bother with a 142+????? I mean does it REALLY make a big difference for the bikes or riders that these 142+ are put on??? C'mon S, you guys are over engineering!
AccordIng to the clearly unbiased individual that I spoke with at S customer service, the '+' makes a significant difference....
#24 ·
damn right! significant difference in the revenue stream!
You know it's ridiculous marketing to the Nth degree when we have XC riders having to pick their brains out between 135, 142, 142+! What's next? 149.3+???
Wasn't it only a few years ago that dh bike rear axel were 135?? So I guess today according to S, an Epic rider has progressed to dh level now. Damn S marketing! haha
#25 ·
Well I had the new 142 rear axle and end caps installed on my DT 240 and the rotor/caliper and not lining up......about 3mm difference...for reference the brake is new xtr 985 and the rotor is RT76 6 Bolt Shimano....not sure what the fix is...
