12 Speed is Dumb!
I’m sure I am going to ruffle some feathers here but here it goes anyway......
On my last bike, I ran a 28T oval chainring and a 10 speed, 11-42 Deore HG rear. Sure, I took a slight beating on top speed and on the super steep hills, but it was cheap, reliable and shifted amazingly well under power. With only 10 gears and using Shimano’s awesome multirelease, I could grab two gears at a time and run thru the cassette quickly to get to the desired ratio.
On my new build, I bought into the 12-speed crap to avoid obsolescence and to get a bit of a larger sprocket on the back to help my aging knees.
I dislike the look of a pizza on the back wheel and the fact that the jump between 2nd and 1st gear is so large. I ended up with a 10-45 on the rear and another 28t oval chainring. This gives me the same low gears as a 32 front/ 52 rear but allows me to use a medium cage derailleur for additional clearance. I lose a bit of top speed, but this is not an issue for me 99% of the time. Looks way better than the giant pizza too.
What I dislike is that hitting a downhill after a big climb, I have to run thru too many gears to get to ratio I like. 12 is just too many and seems to be unnecessary. The gaps between the gears are too small for me and then the gap to the big ring on the 51 or 52 tooth cassettes is just dumb.
I rented a bike this week in Sedona with a 12 speed XX1 mechanical drivetrain. How do you SRAM fanboys deal with not having multirelease – like Shimano? (MULTI RELEASE | SHIMANO BIKE COMPONENT | SHIMANO BIKE-EU) It takes forever to go thru the cassette for a downhill after a climb. Seems like AXS is the only solution in this case. Honestly, my 10 speed Shimano shifted better than this mess too. (to be fair, I feel the 10-speed shifts better than my XT as well).
My new plan is to get a 10-51 XT cassette and cut the big ring off (have not checked to see if this is possible yet). This gives me an 11 speed, 10-45 that is lighter and can still use my current 12 speed shifters, chain and chainring and driver. Shimano used to make an XTR cassette exactly like this a few years ago. One less gear to have to go thru and the ratios are spaced out a bit better. Seems like E13 has the right idea with some of their cassettes but I am not ready to go there yet.
Have a Happy New Year, y’all!
