1 - 11 of 11 Posts
· Registered
Hi all,
Going to tubeless this year after too many pinch flats. I was going to run UST Nevgals on my Flow rims but read that they tend to delaminate fron the inside out when using Stan's sealant.
The Schwalbe Big Betty's seem like a good alternative for our terrain, but the UST version is listed at 1100 grams. Can I get a seal on a Flow rim with a standard tire ?(preferrably kevlar bead)
Thanks for any input.
· meow meow
p nut said:
@ b-kul -- Check notubes site. They've got a list of tires that they recommend. I run regular Rampage and Saguaro's tubeless and have had no issues.
nice, thanks for the info. i had checked the site and saw the list, i was just curious about panaracer, but seeing as how you run the rampage i should be good. was it a real pain to mount and seal or was it more or less par for the course in difficulty?
The Rampage was easier to set up than the Saguaro's. I only needed my floor pump to air up, whereas I needed a compressor for the Geax Saguaro's. However, the Rampages must be more porous, as at first, it lost air much faster than the Geax. This lasted for a couple of rides (no dramatic air loss during the ride, but upon checking a day or two after). But now, they both hold air about the same.
· meow meow
thats awesome to hear. was the geax a tnt tire?
1 - 11 of 11 Posts
