I did a couple of quick searches on this and didn't turn up much.
I'm setting up my Marzocchi Z1 Light ETA fork on my Six Pack and am trying to figure out the sag. I weigh 170lbs, and if I put more than 10psi in the fork, I get less than 40mm of sag. I have the compression damping dialed completely off.
I thought normal pressure for this fork was around 40 psi at my weight :skep: Is it normal to be relying mostly on the spring in the left leg for compression? Anybody else around my weight running this fork on a Pack/RFX? What pressure are you putting in it?
