Jenson are selling the chromo hardtail frames. A buddy is thinking of building one up. That's about all I know.
Maybe. I have read the 2.1" only reports and have seen bikes with (big) 2.3 tires on the back.red5 said:word of caution, (IMO) tire clearence s*cks! Largest tire you can fit would be a 2.1.
The Zion 853 EBB SS I bought last year (size 19) had crappy clearence, as stated previously a 2.1 was the largest and even that was tight for my taste. I actually ended up selling the frame and buying a Surly 1x1, talk about clearence.shiggy said:Maybe. I have read the 2.1" only reports and have seen bikes with (big) 2.3 tires on the back.
They have made quite a few different frames, models and variations. Once they sell through they have something else made.
HardDrive, That's a 19.HardDrive said:Thanks for the pic. What size is that frame? 17 or 19 inch?
What is the tire clearance like on the frame?crisillo said:This is an old pic of my 853EBB Zion, I have changed the cranks, seatpost, stem, tires, front brake rotor and handlebar since then. I am very happy with it.
Cheers,
Cris
I just got back from a ride and had a chance to take some pics to answer your question. These are taken with a Schwalbe Nobby Nic 2.25 on a Mavic XM 317 rim (53mm tread width). Please note that this is last years 853EBB, so I don't know if the current ones have the same clearance. I am happy so far since mud around here in Saarbrücken is not sticky, so I haven't had any issues.Lumbee1 said:What is the tire clearance like on the frame?
For those who can't do the conversion, 53mm makes the 2.25 Nic a 2.09" tire.crisillo said:I just got back from a ride and had a chance to take some pics to answer your question. These are taken with a Schwalbe Nobby Nic 2.25 on a Mavic XM 317 rim (53mm tread width). Please note that this is last years 853EBB, so I don't know if the current ones have the same clearance. I am happy so far since mud around here in Saarbrücken is not sticky, so I haven't had any issues.
I hope this helps.
Cheers,
Cris
On this note, please take into account that the casing is a couple milimiters wider than the thread, when this tire is mounted on this 17mm wide rim. Schwalbes tend to be "smallish", but of course a wider rim would give other measurements.red5 said:For those who can't do the conversion, 53mm makes the 2.25 Nic a 2.09" tire.
Yup. Article attached in PDF. It's 2mb and a little slow. Right click and "Save Target As" to save it to your computer works better.TrekFan said:i think they reviewed a zion in last month's MBA. they liked it and said they won a race or two with one...
Here is the article in jpg, you can find even higher resolution versions if you click on the jpgs.tlg said:Yup. Article attached in PDF. It's 2mb and a little slow. Right click and "Save Target As" to save it to your computer works better.
MBA Zion Review
