yeah that's what i was thinking
Roy said:
He can just score some grooves in the bushing with a hand file or a dremel; not much to it.
yep last time i had the bushings out they looked very similar to the Turner bushings. I've forgotten what the groove on the turner bushing looks like...is it a spiral groove that transports the grease to the left and right portions of the bushing? or just one groove that is perpendicular to the pivot axle, and is aligned with the zerk fitting?
installing the zerk shouldn't be an issue. after all, turner's web site implies that it is very low tech.."if the fitting comes out due to greasing pressure, simply clean up the hole and reinsert the fitting" or words to that effect.
when you start drilling or cutting a frame, any frame, it usually compromises warranty.
incidentally, those ellsworth bushings have been VERY durable. since most of my riding is in dry california conditions, i can go months--even 1+ years--without taking them apart for regreasing. and if i ride in wet conditions and they get squeaky, i sometimes dribble synthetic motor oil on top of the bushing interface, and work it in by moving the suspension (w/ the shock removed)...usually cures the squeak. the industry rumor back then was that Tony Ellsworth strongly believed large bushings made for a stiffer frame at lower weight, but back then Intense was taking his market share and really promoting the idea that so-callled sealed bearings were 'better', so Tony reluctantly had to switch to cartridge sealed bearings.
anyway.... it would be cool to have zerk fittings for proper maintenance on my old truth.
