XL. But if you do, let us know. If it works for you, it'll likely work for the rest of us.At 230 I'd make sure to demo ride it first. That rear end isn't looking like it's gonna be really stiff under big guys.
No evidence either way right now, expensive way to beta test.
Not sure I follow you- after following the Sniper debacle, which I had pre-ordered, there's no way in hell I'd buy one of these.XL. But if you do, let us know. If it works for you, it'll likely work for the rest of us.:thumbsup:
Not following you here.. Should I be looking at a more robust build like the Jeffsy instead? Canyon and YT are on my short listNot sure I follow you- after following the Sniper debacle, which I had pre-ordered, there's no way in hell I'd buy one of these.
Since not everyone was following that, I just felt a warning was in order.
Basically yes. Like I said I could be wrong, but based on what happened with the Sniper which has a similar design (arguably stronger), I wouldn't be the first in line to buy one.Not following you here.. Should I be looking at a more robust build like the Jeffsy instead? Canyon and YT are on my short list
What I’m saying is: the IZZO certainly looks nice....on paper. But after reading the PB review, I’d be skeptical. But, the Sniper had a well known issue (or intentional design that didn’t work for some....depending on who you ask) and plenty of people bought those. Same with SB100.Not following you here.. Should I be looking at a more robust build like the Jeffsy instead? Canyon and YT are on my short list
If you look through the pictures of the Izzo, it does have a brace.Basically yes. Like I said I could be wrong, but based on what happened with the Sniper which has a similar design (arguably stronger), I wouldn't be the first in line to buy one.
Look at the rear end, you're depending on the connection to the rocker for the stiffness in the rear. The YT has no upright member between the seat stay and chain stay, the Sniper had one.
Brace or not, if a 165lb rider is having issues with flex enough to buzz the tire on the stay, a 230lb rider is going to REALLY have issues with flex.If you look through the pictures of the Izzo, it does have a brace.
It's time to ask the Pinkbike reviewer, who's the only reviewer in any website to experience it, if he thought it was lightweight XC tires or if he tried it with beefier tires with stronger walls.That is definitely a problem, lets see what comes out of the first deliveries and if others face the same issue.
I'd think XXL. I'm 6'5" (36" inseam) and ended up passing on this bike partially due to the lowish stack height and the fact that YT owners say YT cuts their steerer tubes short. I would have had to run a really high riser bar on the XXL and there's no way I'd consider an XL.I'm 6'4" with a 35.75" inseam and debating between a XL or XXL.
