On a side note your klunking could be from the lower chainstay pivot. Remove the bolts take out the thru axle bolt clean everything grease everything and reasemble. Be careful of the thin spacers.
yogreg
1) What type grease do you recommend and 2) would you know the size allen wrenches needed for both the pivot bolts on the red pivot link (front & rear)??? Mine has worked loose on the smaller sized allen bolts. No clunk yet when riding but feels like the rear wheel shifts slightly sometimes. It is visible at the red link if you flex the wheel sideways on the frame by hand. Tightened it with the closest allen wrench I have and has pretty much eliminated the play but can’t find the exact right size in my mix-matched set and don’t want to strip them out. 3) Seen others recommending loc-tite is that your recommendation also??? I am still waiting for the heim bushings from Progressive and the sleeves from IH to reduce the play there. Thanks for you expertise!
yogreg
