1 - 18 of 18 Posts
I have Mavic 819 rimes, but am using with standard tires and tubes. I now need to remove a tire for the first time - but lordy, how do I get the darn thing off!
Pushing the bead on one side is supposed to release it from the rim, but it's not budging at all.
Is there a secret to this?
Did you try to use Tire levers?
They are like 10 bucks.
http://www.parktool.com/products/detail.asp?cat=17&item=TL-1
Premium Member
Premium Member
snoogly said:
Thanks shiggy - but it's breaking the bead loose that is stumping me (almost literally). Bead not budging from the rim at all.
"Use your thumbs to push the tire bead away from the rim bead (toward the center). Do one side at a time."
Lay the wheel on top of a plastic garbage can if you need more leverage. Push towards the floor.
squish is good
I've used a flathead screwdriver with tape to prevent metal on metal contact in this case before. Just use it to pop the bead out of its groove, not to pry the tire over the rim! Once the bead is out you can drop the opposite sides bead into the groove and then try rotating the tire towards the side you want to remove it from. I've found that mavic 8** series rims to be a royal pain in the ass so plastic tire levers can be helpful. The bead seat design on those wheels is designed to keep a tire sealed without a tube, not for ease of changing so I wouldn't feel bad about reefing on it with a lever. I have had very poor experiences with metal levers, plastic ones are really the way to go, they won't scratch or damage the rims at all.
Shiggy, I think that Tubeless rims are a whole magnitude of difficulty to get beads to release and tires off the rims. That instructional article is helpful but I don't think it takes into account a tubeless rim.
Premium Member
Gawd NO! NEVER use a screw driver, even if you "pad" it.
The issue here is popping the bead loose. Once the bead is free the removal technique is the same. I have never needed a lever on 819 rims, with or without tubes. Never takes me more than 40-50 seconds either.
Use the garbage can support, your thumbs and you body weight for the tough ones. It is not that difficult!
Fortes Fortuna Iuvat
OP is running tubes... tire really shouldn't be stuck to the rim at all. Weird. :confused:
I have occasionally needed a tire lever for my 819's, depends on the tire manufacturer. Some slide on easy, some are tighter than a high school girl on Prom night! :D
-DL
trail addict
Kastnerd said:
Im sorry to ask this, But are you sure all the air is out?
That's what I was thinking... you need to really get as much air out of the tube as possible-having it kinda soft isn't good enough. Push on the valve stem while "squishing" the tire to get every bit of air out that you possibly can.
1 - 18 of 18 Posts
