SB100 vs other bikes
Not to change the subject, but I thought I'd share some thoughts on the SB100 compared to other bikes I've been riding. In the last year I owned a transition smuggler, then a 2019 Kona Hei Hei and I had a Blur and an Epic evo on long-term demo. Ultimately I bought an SB100 a couple weeks ago.
The hei hei is the 100mm version with shorter geo. The suspension is noticeably inefficient compared to the blur, evo and SB100. In order to stop pedal bob I had to run a lot of compression dampening. Other than that it rode quite well. It was my main bike and I rode it on everything but double-blacks here in Squamish. Sure, I was under-biked a few times but it was fine. I found steep, technical climbing challenging though. The ST angle is 74degrees, but the main reason it wasn't the best technical climber was that the suspension would sag into the travel on steeper climbs, making the effective ST angle even slacker. If I locked out the rear suspension in those situations, it climbed well.
The Blur was my favorite bike (until the SB100). Super efficient, snappy and capable. I was going to wait for the 2022 model, but I got impatient.
The smuggler has the same geo as the new spur. Unlike the spur, it was heavy and the suspension was super inefficient for pedaling. I mean super inefficient. The geo was good for steep stuff but I found I had to pay attention on flatter terrain as the front would wash out. Overall the better geo did not mean I rode steeper stuff than I did on the blur or hei hei. I probably could have but I hated the pedaling and flat terrain handling so much I never rode it.
The 2021 s-works epic evo is nice. Very efficient pedaling in open mode and super light. The down side is that the the suspension feels a bit harsh compared to the other bikes. The cockpit was the same size on all the bikes, but the ST angle and reach were different. The epic has 10mm longer reach than the hei hei but 15mm less than the smuggler. Even though its not super long or slack, I was surprised to find that I still needed to watch when I was really pushing it in flatter corners. I crashed a few times which never happened on the hei hei or the blur. It performed well on some pretty techy downs, except for the harshness.
After all that, I realized that I didn't want something too long and slack. I was in the queue for a spur but then I realized I actually wanted something with more moderate geo, that has super efficient pedaling that is not harsh. Hence the SB100.
All I can say is, wow. The suspension is so stable when pedaling. Again, I found the main limitation for steep techy climbing is how high you sit in the travel. So even though the ST angle on the SB100 and Hei hei are similar, the SB100 is so much better on that stuff. In fact the ST angle on the epic and smuggler are steeper than the SB100, but they do not climb steep stuff any better. The SB100 is by far the most supple on the downs. I also owned a bunch of hardtails and the thing about a hardtail is you get knocked off your line and its hard to focus with the rear end flying around. I noticed that same kind of thing a bit with the hei hei and epic relative to the SB100, but obviously to a lesser extent. I am probably faster downhill on the SB100 because the suspension is so much better, even though the HT angle is slacker on the epic.
Could it be that just maybe there is too much emphasis on geo lately? At least in terms of the bikes I've owned, the suspension design was a bigger factor than the reach or HT/ST angles. Obviously if going fast downhill is your main priority, then its a different story. But the conservative geo on the Hei hei and I guess the SB100 does not stop me from riding steep stuff, I just ride it slower than I would on say the smuggler. But the upside is that the front end is much more stable on flatter corners. Overall, I couldn't be happier with the SB100...except that I am afraid I'll start hearing the dreaded creak at some point!
