I've skimmed the vast majority of this thread since I got my SB100 a couple of months ago. Since then, I've been tinkering with fitment and suspension settings. I see a lot of discussion regarding frame size, but not much regarding actual suspension setup, so I'm wondering if anyone has any suggestion.
To start, I'm 5'11" 185 with gear (probably) riding a large. 2.35 Forekaster up front and 2.3 Aggressor rear. Usually run about 23psi, but could probably go lower.
I set sag initially using Yeti recommended psi per my weight. Seemed close, but was never using all the travel, so I found myself lowering psi by 5 here and there. I never really have found the bottom of the travel, so I just kept reducing it and haven't really seen any loss in pedal efficiency. Obviously, reducing it did allow things to be a little more plush.
Current specs:
Front: 68psi and 9 clicks out on Rebound.
Rear: 185 and 9 clicks out on Rebound.
The rear feels pretty good. Surprised I've gotten all the way down to 185 and still feel like it has that snap out of corners and certainly doesn't bob much at all on climbs. I can see the rear triangle move while pedaling, but that movement doesn't seem to result in any loss of efficiency.
I also thought that I had the front pretty close until the last ride. I rode a longer loop than I usually do that had some sustained downhill sections with some a lot of roots, rocks, small drops, etc. Those kind of obstacles that are separated just enough that the first one hits your rear tire exactly at the same time your hit the next one with your front. I don't know if I want to say the fork felt overwhelmed, but that small (medium) bump compliance was definitely pretty harsh. I guess I'm curious regarding other folks' setups (knowing a lot of this is purely subjective). I'm also wondering anyone has any suggestions for me. My first thought was that the front might be packing a little bit due to the lower psi, so maybe add some rebound.
Finally, Yeti and Fox both indicate that the open mode adjustment has something like 22 clicks of adjustment. I know most people are running this mostly open, but mine seems to only have 5-6 clicks of adjustment available. Am I missing something?
