Yeti Cycles releases the newest addition to their mountain bike line with the unveiling of the SB100 and SB100 Beti. A trail bike with an affinity for XC, the SB100 utilizes an all-new Switch Infinity mechanism redesigned, repositioned and optimized specifically for this shorter-travel twenty-nine-inch wheeled bike.
2019 Yeti SB100 Frame
The all-new Switch Infinity mechanism is redesigned, repositioned and optimized specifically for this shorter-travel twenty-nine-inch wheel bike.​
Yeti's proprietary Switch Infinity suspension platform is known for its flexibility in tuning suspension kinematics and ride characteristics compared to traditional link layouts. The new smaller mechanism is turned 90 degrees and tucked neatly behind the seat tube. This allowed Yeti to achieve an uninterrupted seat tube to accommodate longer dropper posts and fit a large water bottle in all sizes while not having to make any compromises on suspension quality.
Switch Infinity
he new smaller mechanism is turned 90 degrees and tucked neatly behind the seat tube.​
The gravity-inspired overall geometry of SB100 coupled with a steeper seat angle and spec akin to a trail bike makes this bike difficult to categorize. As intended, the SB100 is an XC climbing machine with the perfect blend of pedaling efficiency and downhill prowess.
2019 Yeti SB100 Frame Beti
The SB100 Beti spec's a lighter shock tune, 170 mm crank arms and a women's specific saddle. It's all shred.​
"We ride every day at Yeti, typically on longer travel bikes," said Yeti president, Chris Conroy. "Whoever is testing the SB100 crushes us on the climbs, which is to be expected. But what's unexpected is we can't drop them on the chunky technical downhill. It's a testament to how capable this bike is."
2019 Yeti SB100 CS Black GX
The gravity-inspired overall geometry of SB100 coupled with a steeper seat angle and spec akin to a trail bike, makes this bike difficult to categorize.​
Both the SB100 and the SB100 Beti feature Fox's new Step-Cast 34 120mm fork as well as SRAM's new DUB carbon crankset across the line. The SB100 Beti features a shock tuned for lighter riders, 170 mm crankarms and a women's-specific saddle.
2019 Yeti SB100 Frame Carbon
New Switch Infinity linkage is tucked behind the seat tube to make room for a water bottle in the front triangle and uninterrupted seat post.​
The SB100 will be ridden by Canadian Olympian and professional athlete, Geoff Kabush. Kabush will be riding the capable SB100 when he defends his titles at the BC Bike Race, Moab Rocks and Downieville Classic.
2019 Yeti SB100 Beti TS X01 Race
Both the SB100 and the SB100 Beti feature Fox's new Step-Cast 34 120mm fork as well as SRAM's new DUB carbon crankset across the line.​
"The SB100 is a short travel bike, but it's made for and excels on technical singletrack," said Kabush. "It has suspension that really works, so it is fun to challenge this bike and see how hard you can push it."
This bike is available in at Yeti dealers globally and offered in Carbon-Series with one kit option, TURQ-Series with three kits options and as a frame only. The SB100 is available in size small to extra-large and the SB100 Beti in small to large.
Head angle is 67.8 and seat angle is 74.2 with a 120mm fork
Head angle is 67.8 and seat angle is 74.2 with a 120mm fork.​
TURQ Series: 5.50 LBS (2.49KG)
Carbon Series: 5.95 LBS (2.70KG)
Price: $3400 frame only
For more information, visit www.yeticycles.com.
