rear wheel has to handle pedal drive force (and maybe brake once in a while) front just spins.tacubaya said:Why does the rear wheel has a cross pattern and the front wheel is radial?
Yeah, but what is the advantage of the radial?jp3d said:rear wheel has to handle pedal drive force (and maybe brake once in a while) front just spins.
Let me go weigh my 2.7 2ply super tacky tires to see which one I should use for my race run!fixtup said:a pretty rad fact...Jared weighs every tire he gets and they vary by a few grams. he writes their weights on the sides of the tires and saves the lightest tires for the main events/races and practices on the 'heavier' tires. there was as much as a 20 gram difference between some of his rear tires, even though they were the same model.
GO GRAVZY GO!
Is .045 lbs really going to make that big of a difference in a race? Thats not even noticable...fixtup said:a pretty rad fact...Jared weighs every tire he gets and they vary by a few grams. he writes their weights on the sides of the tires and saves the lightest tires for the main events/races and practices on the 'heavier' tires. there was as much as a 20 gram difference between some of his rear tires, even though they were the same model.
GO GRAVZY GO!
They say rotating mass = 3x static mass, so for 2 tires, that'd be like removing 0.264 lbs from the frame. And when times are separated by hundredths of a second, maybe it does matter...Madman133 said:Is .045 lbs really going to make that big of a difference in a race? Thats not even noticable...
Weight! radial uses much much shorter spokes, and the less mass you have the better. Especially rotating mass.tacubaya said:Yeah, but what is the advantage of the radial?
