If I am not mistaken, AZmtncycler's is a coil lyric (most of them are black from what I have seen, and the 2 steps seem to be grey/silver)lornibear said:I am currently riding a RS Pike 140 Air U-Turn which I am thinking of putting on my Scott MC10 wound down to 130mm. I like the look of the Lyriks but can't make my mind up whether to get Air or Spring. I am a large chap at 230 pounds but have a very good fitness level.
The orange 575 with the Lyriks is a lovely machine. Could you tell me what version you have? It looks like the coil to me. Is that picture with the forks wound out to 160mm? Would love to see a side profile so I can see the geometry.
I read too many reports of problems with the air versions and coils always ride better than air WRT small bump compliance. Here's a side profile but NOT wound out to 160mm ( 135-140mm will be my normal range)lornibear said:I am currently riding a RS Pike 140 Air U-Turn which I am thinking of putting on my Scott MC10 wound down to 130mm. I like the look of the Lyriks but can't make my mind up whether to get Air or Spring. I am a large chap at 230 pounds but have a very good fitness level.
the addition of the heavier fork and wheel. So.. that puts it at @31 pounds. Of course I could have gone with a lighter wheel but wanted a reaaaaalllllly stiff front end so opted for the mavic 823 with straight gauge spokes and brass nipples on a cheap Marzocchi 20mm hub.lornibear said:What total weight is your machine witht the Lyrics? I am pretty much running the same bike as crisillo with mostly XTR with Avid Juicy Carbons. I am just trying to estimate what weight my bike will be with the Coil Lyrics.
OT: What width Nevegals are you running on you tangerine dream?AZmtncycler said:I read too many reports of problems with the air versions and coils always ride better than air WRT small bump compliance. Here's a side profile but NOT wound out to 160mm ( 135-140mm will be my normal range)
These pics show current tires being Kenda Kinetics 2.6" sticky rubber front and rear. These are NOT as big as the 2.5" Nevegal. In the past, I've used the big 2.5" Nevegal up front and 2.35" in the rear. All single ply tires with "Sticky rubber" compound running tubeless with homemade sealant.joltz said:OT: What width Nevegals are you running on you tangerine dream?
