If you like to spin and you can't make some climbs, it might not be a bad idea to adjust your gearing if you want to clear everything. You said you like to spin so it might not be bad. If you increase your crank length you'll spin slower. It is unlikely that the added leverage would be enough to magically make you power up climbs. You're better off practicing better form and trying to keep more momentum if you want to keep your gearing. I've found that form is more important to clearing things than power.
